I am trying to establish a couple of local voice assistants in my home.
Until now we have a google Nest or Nest Hub in every room to communicate with the smart home.
I recently tinkered with a m5 STack and ordered a couple of ESP32 S3 N16R8, MAX98357A and INMP441.
The goal is to use them to control the lights, shutters and local functions.
So far I built three Devices and they work more or less ok.
However some stuff is missing, I would like to have a chime wehn it detects the wake word and what to be able to make announcements to them.
I have doctored the following yaml but I am not able to play the wave file, or send announcements via Home assistant.
substitutions:
timer_alarm_sound: "sounds/bell.wav" # in the esphome/sounds folder
esphome:
friendly_name: Oscar Nr. 3
compile_process_limit: 2
platformio_options:
board_build.flash_mode: dio
on_boot:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 60%
effect: "Scan Effect With Custom Values"
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
mode: octal # Please change this to quad for N8R2 and octal for N16R8
speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
output_power: 8.5dB
ap:
ssid: "Oscar-3 Fallback Hotspot"
password: !secret fallback_ap_pw
captive_portal:
i2s_audio:
- id: i2s_in # For microphone
i2s_lrclk_pin: GPIO3 #WS
i2s_bclk_pin: GPIO2 #SCK
- id: i2s_speaker #For Speaker
i2s_lrclk_pin: GPIO6 #LRC
i2s_bclk_pin: GPIO7 #BLCK
microphone:
- platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO4 #SD
channel: left
pdm: false
i2s_audio_id: i2s_in
bits_per_sample: 32bit
output:
- platform: gpio
pin:
number: GPIO8
allow_other_uses: true
speaker:
i2s_audio_id: i2s_speaker
dac_type: external
i2s_dout_pin:
number: GPIO8 # DIN Pin of the MAX98357A Audio Amplifier
channel: mono
#media_player:
# - platform: i2s_audio
# name: "esp_speaker"
# id: va_speaker
# i2s_audio_id: i2s_in
# dac_type: external
# i2s_dout_pin:
# number: GPIO8 # DIN Pin of the MAX98357A Audio Amplifier
# allow_other_uses: true
# mode: mono
voice_assistant:
microphone: va_mic
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 4.0
use_wake_word: false
speaker: va_speaker
on_error:
- if:
condition:
switch.is_on: use_wake_word
then:
- switch.turn_off: use_wake_word
- delay: 1sec
- switch.turn_on: use_wake_word
on_wake_word_detected:
- if:
condition:
lambda: return id(wake_up_bell_active) == true;
then:
switch.turn_on: wake_up_bell
- light.turn_on:
effect: "Fast Pulse"
red: 100%
green: 100%
blue: 100%
brightness: 80%
# zuhören was nach dem wakeword gesagt wird
on_listening:
- if:
condition:
- switch.is_on: wake_up_bell
then:
- lambda: id(va_speaker).play(id(timer_finished_wave_file), sizeof(id(timer_finished_wave_file)));
- switch.turn_off: wake_up_bell
- delay: 50ms
- light.turn_on:
effect: "Slow Pulse"
red: 0%
green: 0%
blue: 100%
brightness: 80%
# (Optional, Automation): An automation to perform when voice activity detection starts speech-to-text processing.
on_stt_vad_start:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 80%
on_stt_vad_end:
- light.turn_off: led_strip
# beginn der sprachausgabe
on_tts_stream_start:
- light.turn_on:
effect: "Fireworks Effect With Custom Values"
red: 0%
green: 0%
blue: 100%
brightness: 80%
on_tts_stream_end:
on_stt_end:
# on_end:
# - light.turn_off: led_strip
on_client_connected:
- delay: 50ms
- if:
condition:
then:
- voice_assistant.start_continuous:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
binary_sensor:
- platform: status
name: API Connection
filters:
- delayed_on: 1s
on_press:
- if:
condition:
then:
on_release:
- if:
condition:
then:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
- platform: template # wake up bell
name: Wake up bell
optimistic: true
icon: mdi:bell
on_turn_on:
then:
- lambda: id(wake_up_bell_active) = true;
on_turn_off:
then:
- lambda: id(wake_up_bell_active) = false;
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO09
num_leds: 4
chipset: ws2812
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
- pulse:
transition_length: 1s
update_interval: 1s
min_brightness: 0%
- addressable_scan:
name: "Scan Effect With Custom Values"
move_interval: 200ms
scan_width: 1
- random:
name: "Random Effect With Custom Values"
transition_length: 5s
update_interval: 7s
- flicker:
name: "Flicker Effect With Custom Values"
alpha: 95%
intensity: 40%
- addressable_random_twinkle:
name: "Random Twinkle Effect With Custom Values"
twinkle_probability: 5%
progress_interval: 32ms
- addressable_fireworks:
name: "Fireworks Effect With Custom Values"
update_interval: 32ms
spark_probability: 50%
use_random_color: true
fade_out_rate: 120
external_components:
- source: github://jesserockz/esphome-components
components: [file]
refresh: 0s
file:
- id: timer_finished_wave_file
file: ${timer_alarm_sound}
globals:
- id: wake_up_bell_active
type: bool
restore_value: false
I struggle to find a good example. All the examples I found lack support or features.
Because I trained my own wakeword I would like to use it, but I don’t know how to get it onto the device so until then I use the wakeword in home assistant set to “hey Oscar” and it works great.
What I need:
- my own wakeword “Hey oscar”
- a chime
- timer
- anouncements
Anyone mind to help me or knows a good example?
