Hi, i want to buy 4 piece smart plugs but i read that a lot of them can not pair when they are more than one and had problems. Could you propose me some brands which i can buy and do not have problems when they are more than one plug and when adding them to HA . Could be from amazon or aliexpress.
I looked and found a lot brands but couldn’t find nothing about them here.
Thanks in advance.
You better state what type of technology you are looking for.
RF on frequency X, Zigbee, Zwave, Wifi or other open or proprietary protocol?
Personally I’d recommend Zigbee - exactly which will depend on your country, but generally Innr and Tradfri (Ikea) work well.
(maybe not) Obviously you need a Zigbee coordinator to use Zigbee devices.
I have never use Zigbee devices but i have Echo 4 which as far as i know has a built-in Zigbee hub and probably they will work.
I have two Broadlink plug but when i add second one the first one became unavailable and one Merros plug which is disconnecting sometimes itself
I am in Bulgaria which Zigbee will be fine for me ?
The Echo won’t act as a Zigbee coordinator for HA.
Bulgaria uses C and F sockets, so most Euro plugs should work for you.
do you think some of this will work ?
https://www.amazon.de/Socket-Measures-Consumption-Google-Control/dp/B0BG4BJ9GD/ref=sr_1_19_sspa?crid=13GQVMMCNVX4O&keywords=tradfri+stecker&qid=1676483235&sprefix=tradfri+plug%2Caps%2C106&sr=8-19-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&psc=1
As a hint, you can edit Amazon URLs and remove everything after the ?
(or after the product code).
Those all look to be WiFi, getting them to work with HA will be painful, though the Tapo ones may work with this custom component.
thanks for the hint about urls.
I am not sure I want to buy Zigbee hub now and will think about Tapo ones.
