flyize
July 17, 2023, 3:22pm
1
My vacuum runs every other day at 4pm, unless no one is home. This automation works perfectly.
However, I’d like to set it so that if it missed the 4pm start time because no one is home - that it send an actionable notification to our phones asking if it should start when we return home. I can handle the notification, but how do I do something like has_vacuum_run to True, then check that variable when we get home?
edit: And if it matters, I’d like to keep all this in a single automation, hence the defined trigger_id.
For reference, here’s the automation in its current state:
alias: "[Time] Run vacuum"
description: ""
- platform: time
at: "16:00:00"
condition: []
- if:
- condition: trigger
id:
- run_vacuum
- condition: numeric_state
entity_id: zone.home
above: 0
- condition: template
value_template: "{{ ((now()|as_timestamp/86400)|int%2) == 0 }}"
then:
- service: mqtt.publish
qos: 0
retain: false
topic: valetudo/roborock_s6/MapSegmentationCapability/clean/set
payload: >-
{"segment_ids":["17","16","19","24","22","23","21","18","20"],"iterations":1,"customOrder":true}
else: []
mode: single
flyize
July 18, 2023, 8:15pm
3
If anyone cares, this is what I ended up with. I created a Helper to store state. I really would rather it store that in the automation, but I couldn’t figure it out.
description: ""
- platform: time
at: "16:00:00"
- platform: time
at: "00:00:00"
- platform: zone
entity_id: person.zac
zone: zone.home
event: enter
- platform: zone
entity_id: person.april
zone: zone.home
event: enter
- platform: event
event_type: mobile_app_notification_action
event_data:
action: run_vacuum
condition: []
- if:
id:
- run_vacuum
above: 0
then:
qos: 0
retain: false
payload: >-
else:
data: {}
entity_id: input_boolean.no_vaccum_run
- if:
id:
- reset_boolean
then:
- service: input_boolean.turn_off
data: {}
- if:
id:
- zac-home
- april-home
then:
- service: notify.mobile_app_zac_s_phone
message: I didn't run the vacuum while you were gone. Shall I now?
actions:
- action: run_vacuum
title: Run vacuum
- if:
id:
- run_vacuum_now
above: 0
then:
qos: 0
retain: false
payload: >-
data: {}
else: []
mode: single
jeffcrum
(Jeff Crum)
July 18, 2023, 8:18pm
4
Use an input_boolean helper.
After your publish to MQTT, set it to on.
In the else, set it to off.
input_boolean.turn_on or input_boolean.turn_off are the commands.
I hope I understood your request.
flyize
July 18, 2023, 8:21pm
5
Yeah, that’s exactly what I did. But IMHO, it really would be cleaner if it were all handled inside the automation.
jeffcrum
(Jeff Crum)
July 18, 2023, 8:36pm
6
Yeah. I saw our posts crossed.
I understand what you wanted. But, there are no persistent or global variables in HA. At least they gave us the helpers!
