I’ve searched “the entire internet”
and tried a few things but am not able to get audio working on my ODROID N2+ for Voice Assistant. I have setup Wyoming, but the audio option is not available when trying Debug. I an using a Jabra 410 USB audio device that seems well identified by Pulseaudio.
Can someone point me in the right direction? Seems like I need to configure something so that HA sees the audio mic and speaker.
Thanks!
Did you try the “Assist Microphone” add-on from the store? Should make things smoother from what I’ve read, although I haven’t personally tried it.
https://github.com/home-assistant/addons/tree/master/assist_microphone
Yes, I had that already installed - thanks for checking. The logs indicate it’s connected ok, yet the Voice Assist does not allow for audio or debugging audio.
dmesg
Wondering if @FredTheFrog has any thoughts as I saw some related Jabra 410 postings.
Most of the Jabra/Linux tech details are posted over at the Rhasspy forums
Biggest things are:
a) when you have multiple USB devices, the Jabra may not always come up as the same port, depending on what else is connected.
b) your ALSA configuration file is critical. I believe I posted those details over at the Rhasspy forums, as well.
