Need Daikin Wifi? Use the Open-Source Faikin ESP32 Hardware instead of the official wifi Modules
Hi @hargathor
Was the connector from vercellino’s post please (the one from Aliexpress)?
I’m struggling as well finding one for the new S21 port…
Many thanks
Great write-up! I am looking for the STL (or STEP) files for the 3D printed case, but can’t seem to find them. Could you point me in the right direction?
They are up on a folder on Github - I think it was PCBCase - the repo has been updated a little. I had to dig through the folders to find the files.
This link is close:
Got it, found it here: ESP32-Faikin/PCB/Faikin at main · revk/ESP32-Faikin · GitHub. Thanks!
I’ve gotten fed up with the ONECTA app/API going down a couple of times this year already, screwing with our automations, so I’ve finally gotten round to buying a Faikin and cheap cable for our Perfera!
Just need to find some time to turn off the isolator, take it apart, and install the thing I guess. It’s a shame it needs internet access for updates (providing files that can be uploaded via the GUI would be better, since no air con controllers should ever be connected to the internet IMO). I will likely update it once it’s first connected then move it to my VLAN with no internet access.
One thing I will miss is the ability to set temperature in 0.5 °C increments though. Shame the local Dakin API never supported that (even though the handheld controllers do)!
I have flashed ESP32 Devkit V1 with Faikin-S1-V1 bin using Flash download tool.
Configure the wifi, MQTT and setting before connect to my A/C.
MQTT log shows it connected, but it does not autodiscover by MQTT, may be because I did not connect to A/C.
Once I connect ESP32 Devkit V1 with 4 ch level shifter module to my Daikin A/C (FTKU series) S21 port via JST EH 2.5mm to dupont 2.54mm 5pin cable and power up the A/C, it immediately added to Home assistant under MQTT.
Temperature, fan control works. However Powerful/Eco mode seem not able to work.
I now facing the issue that the temperature step is 0.5degC, I would like to change to 1.0degC. But I cant find the way to change it. Anyone can advice?
p/s: The JST EH connector I purchased is from Aliexpress link below. It matched with FTKU series model, not sure others.
https://www.aliexpress.com/item/1005005465484217.html
I would check with the developer on Github - but search first!
He has included a lot of features that you can enable just by sending a command to the unit via MQTT.
could easily be a limit of your unit.
Also you say you have 1° step, quite sure you’ll also not have power consumption reported by the split.
Old units have less functionalities than newer ones (mine too can’t set powerful/eco via S21, even if i can set them via remote controller…)
Hi, anyone here using FTV-P models, i don’t see this listed on faikin compatibility list
Also, how difficult would it be to check for s21 port?
Would I need to remove all the cables before I could pull out the pcb?
you do not need to pull out the pcb
you just need to take out the cover, then there is easily a metal cover (just pressure) and under that you can see the board.
Then it’s just about looking for an empty S21 socket :slight_smile:
very very easy
Thanks, just saw a video of someone installing AWM61A01 dongle and he just took off the entire enclosure and the port is visible on the side.
My model comes with built in wifi apparently so I’ll need to check where it’s hooked up to. Hopefully it’s s21, i’m seeing a few other ports discussed in the github
Hi, i’ve opened it up.
Looking at the diagram, the wifi dongle needs to connected CN_WIR port
What do you think?
It sure looks like it - but I am not familiar with this model at all. Seems to have more pins than the S21 port. So, it seems reasonable to me. You would need to know the pinouts too.
Looks like you might be the first to try this though - I can’t find any other references to other people using this port. I would guess the protocols are the same as it would be expensive to change them up.
I’ve added discussion here
Looks like even the awm61a01 wifi dongle is only using 4 cables/pin
Ok, so I just browsed esp8266-faikin and
FTXB50C - CN_WIRED protocol is listed there so I assume this should work with the right pinout.
Hi @Mr_Flibble can faikin display additional details like below?
I was asking around and this is using the daikin integration with BRP072C42 wifi module
Yes:
Thanks, didn’t see any mention of other sensors other than ble on the github.
No power monitoring listed?
It depends on what your unit supports, not all units feed those metrics back.
I see, so only select/newer ac model comes with power monitoring support
Hi, I’ve plugged in the jst connector to CN_WIR port, I think I’ve got the 5v & gnd pin right because the LED on the d1 mini is blinking which does indicates it’s already boot up.
I did see the faikin access point for a few moment, and then it wasn’t visible anymore.
So I removed the d1 mini and plugged to my pc, I was able to connect to the access point and setup the wifi and it’s now connected to my network.
I plugged it back again to the ac, but doesn’t look like it’s connecting to my wifi network with the led still blinking.
What do you think?
