I just installed HA and am currently learning the interface and how to do the automations my goal is to have. I have a few questions regarding how to achieve my goal and will therefore describe my goal below and then add the questions at the end to give you guys the whole picture.
Daily flow:
My goal is to have certain lights slowly turn on when I disable the sleep focus mode on my iPhone provided that I’m home and it’s dark out. I then want all lights except the window lights to turn off when I leave or at sunrise depending on which comes first. I want the window lights to stay on if I leave and turn off only an hour past sunrise.
I then want the window lights to turn on again an hour before sunset. All the other lights except for the bedside lights I want to be turned on at sunset if I’m home and when I get home otherwise.
I then want the lights to turn off again when I activate the sleep focus mode.
TV usage
On top of this daily flow I want the TV to be a part of it as well. I have an LG C2 which I’ve integrated to HA. If possible I want to turn most of the lights off when I play something except Spotify on the TV, otherwise whenever the TV is turned on. I then want to turn the lights back on again when the TV is paused or turned off depending on what’s possible provided that the daily flow says that the lights should be on.
Additional information
I don’t know if this matters at all in this case but I’ll add it in case it is. I’m running HA through Proxmox on a Beelink Mini S12 Pro. All my lights are from IKEA and they’ve been integrated as HomeKit Devices using the Dirigera Hub. I’ve also added HomeKit Bridge in order to sync things with the Home app on my iPhone. I’ve also installed the HA app and set the location to always allow. Everything is connected to a Ubiquiti UCG Ultra which also has been integrated. And the TV in question is an LG C2 which has been integrated using the default LG WebOS option.
My questions
How would you guys go about creating an advanced flow like this? Would you use a small amount of advanced automations or a bunch of small ones? How would you make sure that the automations work together rather than against each other?
Is there a blueprint or guide on how to achieve something like this? Are there any articles, videos, previous topics or anything else I can use to read up on the best practices in terms of advanced automations like this?
Even though a step-by-step guide would be awesome I’m fully aware that that most likely won’t happen here but all tips, tricks, recommendations, links and more are greatly appreciated!
