I run Home Assistant in a KVM on Proxmox. On a different KVM, I also run a Prometheus server. If you’re not aware, Prometheus is an industry-standard way to gather metrics from remote servers into one time-series database. You can use this data to monitor/graph/alert on problems with your servers.
Every one of my KVMs runs Prometheus Node Exporter. Node exporter creates an HTTP page on every KVM at http://server_ip:9100/metrics
, which allows the Prometheus server to scrape Linux OS and hardware metrics at a specified interval.
My issue is, Home Assistant doesn’t support Prometheus Node Exporter, it only supports Prometheus exporting sensor/entity data, but I want to publish data about the host KVM (e.g., CPU/Memory/Disk), not my sensors/entities.
I have created a very rudimentary local add-on that works to publish my KVM host’s metrics at http://server_ip:9100/metrics
. However, I’m not a seasoned HA developer, and would like someone to look at this code. Especially considering the add-on requires privileged, unprotected access to everything on the host.
Is this forum the right place to post this request? I thought about contacting @frenck to include this the official Prometheus integration, since it would be just publishing some addition metrics, but he seems very busy. I also considered the Edge Add-ons repository, but they are apparently not accepting new add-ons. Should I contact someone at HACS, or is there someone here who can assist me?
Thanks in advance!
