Hello everybody I am new on home assistant and my english is little poor (I am french), so I will do my best.
It is several days that I try to install, and configure my RFX sensors (switches, temperature and so on).
I have read a lot of topics and have sawn videos (and the offical documentation which is not very enough for me) but nothing is working.
So I would like to persist with Home Assistant (I become Jeedom).
Is there someone who will have a really precise topic about RFXcom ?
Can you maybe share more info on the sensors you’re trying to use?
Can you also confirm which RF Hub you’re using?
Ideally share the part of your config where you defined the RFX connection…
First thank you very much for your hand.
I have different kind of sensors. The first one I try to reach is Chacon Ref 54661. When I was on Jeedom project it was working perfectly. I have the ID to switch ON : 0A14110100306402010070 and also to switch off : 0A14110200306402000070. So I directy tried to insert that in the yaml config but… nothing. So I tried the auto discovering by reading different tuto but…nothing.
I use a RFXTRX 433e witch I have flash few monthes ago.
Here is my last config I tried a lot of things (also :device: /dev/ttyUSB0) and I think it is the good port (the same that Jeedom) That 's why there is a lot of #
Configure a default setup of Home Assistant (frontend, api, etc)
can you format your config ?
Select the code and use the </> to mark it as code.
This will make it much easier to help
Also please confirm your HA setup (docker container, core, homeassistant (aka hass.io) etc
Tell me if it is better
And Sorry I don’t understand what you mean by " Also please confirm your HA setup (docker container, core, homeassistant (aka hass.io) etc"
There has been a massive breaking change to the rfxtrx integration with version 0.113, which caused all kinds of problems for many people, basically breaking everybody’s configuration. That is probably the reason why most tutorials or older forum posts you may find about this subject won’t work anymore. The documentation about the ‘new’ rfxtrx integration is also far from good, but apparently they’re working on improving this.
Your config, at least the commented part, looks like it still uses the old integration settings.
Can you describe your problem in some more detail ? What exactly is not working, any error messages in the log, what did you already try, etc.
Et pas de soucis pour l’Anglais, il est très bien, t’inquiétes
yes I have read that. It’s the reason why I firstly observe de parution date of the topics about this subject. For me the official documentation is not enough prcise for beginer.
Like the other post I will take my time to reply you because I would like giving you a precise reply.
Ouf ça va alors si mon anglais est decodable…Merci en tout cas pour ton aide. Je ne vais pas polluer le forum, si je n’y arrive pas je resterai sur Jeedom malgré les instabilités que je constate.
Don’t give up yet. I think your problem is just a config thing and I’m sure we can help you get it up and running. I have an RFXCom with lots of Chacons and Oregon Scientific stuff and it’s extremely stable and reliable.
That ‘update’ that came with 0.113, even if it might have been technically necessary, was a terrible mess and very poorly executed. You’re not the only one who had problems getting things running again. The fact that the rfxtrx integration documentation is a huge mess doesn’t help either. But they’re working on it. And once you get around setting the RFXcom up with HA, things are very smooth. The integration itself works perfectly.
Post some details and your (readable ) configuration and we’ll do our best to help you.
I then renamed my RFX devices to something easier to recognise then their ID (hence the comments in the config to keep tracking)
I can’t be sure until you format your config correctly but it looks as though you’re almost there…
Well, the OPs unformatted config is kinda readable. So I think if the commented out device ID / event code is a valid one, the config entries for him would look something like this
In configuration menu, “appareils”, I found a device named Kangtai 003064:2.
When I klick on it I view 3 things and one is a switch when I click on it it toogle my plug.
So I can put it in Lovlace UI.
I don’t understand why the name between config.yaml and the device is not similar.
That is working but I don’t know why…
Good news you now know how to mark your config as code
Each device has an ID
That said there is also other info sent by each device and this additional info is used by the RFX integration to help the user identify each device.
Devices that are automatically discovered do not need to be manually added.
You can change the name of each device to something more meaningful to help you.
In my example, 0A14110100306402010070 is the ID of my garage back door sensor (hence the comment in my config. Comments indeed start with # and are ignored by the system)
0A14110100306402010070 means nothing to me so I renamed it. In the RFX Integration, I located the id and then clicked on it. Then I clicked on the cogwheel (top right) to rename the device to Garage Back Door)
I then manually also edited each entity and replaced the id with a lower snake_case version of Garage Back Door:
