Need help adding a Honeywell Lyric Thermostat
Hello. I’ve tried to add a Honeywell thermostat, and now i get this error :
{“code”:400, “message”:“The redirect URL provided does not match the redirect URL registered for the app.”}.
The integration is not allow me to modify it, how can I fix my issues?
That message in most circumstances is the result of an Oauth request to a web site, and those requests must then redirect back to the caller to let them know their access token. In your case, the caller is HA and generally you add the redirect back to HA via Nabu Casa or your local firewall if you have an SSL certificate installed on HA.
I don’t know anything about the Lyric integration but the message is basically saying it cannot call back to you, is there a setting on the Lyric website you may have missed?
