Need help. Can't Install latest hassio-supervisor
Been searching for a solution for days. It’s above my paygrade.
19-04-13 13:47:51 ERROR (SyncWorker_5) [hassio.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:latest:159 -> 400 Client Error: Bad Request ("no such image: homeassistant/amd64-hassio-supervisor:latest:159: invalid reference format").
2019-04-13 09:48:48 ERROR (MainThread) [.] Error connecting to the Hue bridge at 192.168.1.26
2019-04-13 09:48:49 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/ping request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
2019-04-13 09:48:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/options request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
2019-04-13 09:48:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/options request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
2019-04-13 09:48:50 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/info request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
2019-04-13 09:48:53 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /discovery request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
2019-04-13 09:48:53 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read discover info:
2019-04-13 09:49:06 ERROR (MainThread) [.] Error connecting to the Hue bridge at 192.168.1.26
2019-04-13 10:43:51 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/info request Cannot connect to host 172.30.32.2:80 ssl:None [Connection refused]
no onehas any ideas?
19-04-14 05:42:14 INFO (MainThread) [__main__] Initialize Hass.io setup
19-04-14 05:42:15 INFO (MainThread) [__main__] Setup HassIO
19-04-14 05:42:15 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor:latest with version dev
19-04-14 05:42:15 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-04-14 05:42:15 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-04-14 05:42:15 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-04-14 05:42:16 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-04-14 05:42:16 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-04-14 05:42:16 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-04-14 05:42:16 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-04-14 05:42:16 INFO (MainThread) [hassio.host.info] Update local host information
19-04-14 05:42:16 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-04-14 05:42:16 INFO (MainThread) [hassio.host.services] Update service information
19-04-14 05:42:16 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-04-14 05:42:16 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-04-14 05:42:16 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-04-14 05:42:16 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-04-14 05:42:16 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.91.3
19-04-14 05:42:23 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-04-14 05:42:23 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-04-14 05:42:23 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/15ef4d2f repository
19-04-14 05:42:23 INFO (MainThread) [hassio.addons] Load add-ons: 58 all - 58 new - 0 remove
19-04-14 05:42:23 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/unifi with version v0.8.0
19-04-14 05:42:24 INFO (SyncWorker_1) [hassio.docker.interface] Attach to hassioaddons/node-red-amd64 with version 0.1.1
19-04-14 05:42:24 INFO (SyncWorker_5) [hassio.docker.interface] Attach to hassioaddons/ide-amd64 with version 0.2.0
19-04-14 05:42:24 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/vscode-amd64 with version v0.2.0
19-04-14 05:42:24 INFO (SyncWorker_0) [hassio.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.12.2
19-04-14 05:42:24 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-04-14 05:42:25 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-04-14 05:42:25 INFO (MainThread) [hassio.discovery] Load 0 messages
19-04-14 05:42:25 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-04-14 05:42:25 INFO (MainThread) [__main__] Run Hass.io
19-04-14 05:42:25 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-04-14 05:42:25 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 159
19-04-14 05:42:25 INFO (SyncWorker_8) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor:latest tag 159.
19-04-14 05:42:26 ERROR (SyncWorker_8) [hassio.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:latest:159 -> 400 Client Error: Bad Request ("no such image: homeassistant/amd64-hassio-supervisor:latest:159: invalid reference format").
19-04-14 05:42:26 ERROR (MainThread) [hassio.supervisor] Update of Hass.io fails!
19-04-14 05:42:26 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<HassIO.start() done, defined at /usr/local/lib/python3.7/site-packages/hassio/core.py:71> exception=SupervisorUpdateError()>
  File "/usr/local/lib/python3.7/site-packages/hassio/core.py", line 77, in start
    elif await self.sys_supervisor.update():
  File "/usr/local/lib/python3.7/site-packages/hassio/supervisor.py", line 115, in update
    raise SupervisorUpdateError() from None
hassio.exceptions.SupervisorUpdateError
19-04-15 01:11:58 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-04-15 01:11:58 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 159
19-04-15 01:11:58 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor:latest tag 159.
19-04-15 01:12:00 ERROR (SyncWorker_3) [hassio.docker.interface] Can’t install homeassistant/amd64-hassio-supervisor:latest:159 -> 400 Client Error: Bad Request (“no such image: homeassistant/amd64-hassio-supervisor:latest:159: invalid reference format”).
19-04-15 01:12:00 ERROR (MainThread) [hassio.supervisor] Update of Hass.io fails!
19-04-15 01:12:00 ERROR (MainThread) [asyncio] Task exception was never retrieved
File “/usr/local/lib/python3.7/site-packages/hassio/core.py”, line 77, in start
File “/usr/local/lib/python3.7/site-packages/hassio/supervisor.py”, line 115, in update
I just reinstalled the whole thing
