Hello all,
Can someone help me figure out how to switch my pi over from Ethernet to wifi.
I am getting the below error when I try to save the network settings.
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:135
integration: Home Assistant Supervisor(documentation , issues )
First occurred: 6:49:52 PM (3 occurrences)
Last logged: 6:50:18 PM
Failed to to call /network/interface/wlan0/update -
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
August 20, 2024, 11:21pm
2
Hello Weston ,
While HA will Technically work over WIFI, it is not particularly stable doing that and is not recommended.
While is not actually
Most people will advise to use an Ethernet wire.
I appreciate that information. Essentially I have a bunch of zwave relays that I can’t get to connect to my stick and the manufacturer said to get the device and hub close together. This I thought was going to be way easier than taking all of the relays back out of the electrical boxes.
I hooked my pi up to the tv and now I am getting this:
.it looks like it has lost both ipv4 addresses.
Solved in the below thread:
Had a situation where a lightning strike took out my ethernet controller on my NUC unit running HAOS. I connected a keyboard and monitor and confirmed HA was starting up, but “Network Manager Wait Online” failed to start. This made it impossible for me to get in via ssh or the web interface. I then used a Ubuntu usb drive to boot the unit and confirmed the ethernet was unresponsive. However, I found the wifi was working properly. After many hours of searching, I used this process to change the a…
