Need help changing ZBT-1 from Thread to Zigbee
I’m an HA noob and need to change my ZBT-1 from Thread to Zigbee. When I go to Settings->System->Hardware->ZBT-1 Configure->Zigbee the follow popup appears:
“This Home Assistant Connect ZBT-1 is in use by the OpenThread Border Router add-on. If you use the Thread network, make sure you have alternative border routers. Uninstall the add-on and try again.”
I deleted the OpenThread integration, but this message still appears. Is the popup referring to a different addon? Am I supposed to uninstall the hardware? I’m a bit confused. TIA
You have the integration
afbeelding
and the add-on
afbeelding
Both need to be removed.
See also here:
Thank you! That did the trick!
