Context:
Just bought some Lumary Smart Recessed Lighting 6 Inch Canless Lights from Amazon, going to be using them as the main floor lighting in my house.
I am trying to get them working with HA over Local Tuya. They will be on a NoT network eventually.
Currently, they are added to the Tuya app, and they can be controlled over the cloud using HA. I also have Local Tuya setup and it works great with my other Tuya-based devices.
The Problem:
The Lumary lights do not get automatically detected by Local Tuya’s automatic discovery. When adding it manually using the static IP and Device ID, and local key, it shoots our an error: “Connection to device succeeded but no datapoints found, please try again. Create a new issue and include debug logs if problem persists.”
I have tried putting DPS in the “Manual DPS” text field using the classic:
- 20 - ID
- 22 - Brightness
- 23 - Color Temp
- 21 - Color Mode
- 24 - Color
- 25 - Scene
Using these DPS it will add the device, but it is unavailable.
I noticed that when using my manually entered DPS all their values are “-1” not sure if that is my problem, but see other people’s on YouTube theirs looks a lot different. See the pictures below:
My screenshot:
I’ve done plenty of research, and tried plenty of different things. I hope I can figure this out, and help others who experience the same issue.
Something to also note: I am on the latest version of HA(2023.9.2), HACS(1.32.1), Local Tuya(5.2.1), and the Lumary Light’s version is V1.5.21.
