Hey all, i cant seem to get my yaml script for controlling my ledstrip to work. i want to have around 20 ish buttons to control all the colors of my ledstrip but it gives me this error:
could someone help me?
here is the full code:
esphome:
friendly_name: ledstrip_controller
esp32:
board: esp32dev
framework:
type: arduino
# Enable Home Assistant API
api:
encryption:
key: "kPBZgEl8RCntx+KFC7Vd/1Tsx5opsPKr89wyRsiiJp4="
ota:
password: "17035faa032c528e62569675e472a0db"
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.2.24
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.2.254
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.254.0
ap:
ssid: "Ledstrip-Controller"
password: "lvUztD6Xbg7k"
remote_transmitter:
pin: 4
carrier_duty_percent: 50%
button:
- platform: gpio
on_press:
- remote_transmitter.transmit_nec:
address: 0xFF00
command: 0xBF40
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xA35C
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xA25D
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xA758
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xA659
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xBA45
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xAB54
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xAF50
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE31C
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE718
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xAA55
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xAE51
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE21D
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE619
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xB649
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xB24D
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE11E
command_repeats: 1
- platform: gpio
on_press:
address: 0xFF00
command: 0xE51A
command_repeats: 1
