Is there anyone who could help me with the following question.
I have a Qubino Z wave energy meter for some reason when the sun is down and my panel inverters go into standby mode the current wattage raises to 1.677.720,6 watts. The meter works fine during the day so no issue there. The kwh value stays the same so that is working also fine.
Without discussion what the reason could be I want to create a template sensor in my config file that will set this value to zero.
In other words it should set te value to zero as soon as it’s wattage is greater than 12000 (the total value of my solarpanels)
Is there anyone who could give me a hand with this
Kind regards
Vincent
