I am configuring my homeassistant run from a venv mostly via the files and not lovelace.
So I just moved all my automations and scripts into seperate files and did the propably usual
automation: !include_dir_merge_list automations
trick in my configuration.yaml
This works fine for all automations except one.
For some reason I cannot get rid of the following error in my log:
Invalid config for [automation]: [platform] is an invalid option for [automation]. Check: automation->action->0->platform. (See /root/homeassistant/configuration.yaml, line 92).
I know which file it is from, because it is the only automation not showing up.
I tried a reloading everything and also restarted homeassistant.
This is the exact content of my file
- alias: "Warne mich wenn ich das Haus verlasse und mein Licht noch an ist"
- platform: state
to: "not_home"
entity_id: device_tracker.nokia_6_2
- platform: notify.notify
message: "Hast du vergessen dein licht auszumachen?"
Could someone please enlighten me on where my mistake is, because I am sure it is just something minor I am currently overseeing.
I usually never post on forums, but I am now sitting on this 10 lines of yaml for the past hour and don’t know what to do else.
