Need help decoding host log
I need some help from a trained eye in spotting what I’m missing.
Backstory:
  • Earlier today HA (core) restarted for no apparent reason. Both core and supervisor logs didn’t record anything beforehand. I only know about it because I happened to be tailing the log file and saw the familiar boot messages out of the corner of my eye while doing something else.
  • Then an hour or so later parts of the HA (maybe) stopped responding (this is the second time this has happened in a week). The frontend was working (I could navigate around, but when I went to the Z-wave integration log, there were no z-wave messages being seen like normal when I trigger the motion sensor on and off that I have on my desk in front of me. It’s set to trigger instantly so i can generate messages every few seconds easily for my testing.
So before I rebooted the host, I grabbed the log file. Below is what was in it. I’m looking for help at pointing our the culprit if there is something in it, and more importantly what I should look for the next time this happens. It says out of memory, but that doesn’t really tell me where to look does it?
Setup (on a RPi3B):
Host log file:
[11950.455396] audit: type=1700 audit(1620434123.738:185): dev=vethe04a2d1 prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295
[211449.831765] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[211451.456013] cp210x ttyUSB1: usb_serial_generic_read_bulk_callback - urb stopped: -32
[240459.856787] python3 invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
[240459.856806] CPU: 3 PID: 80153 Comm: python3 Tainted: G         C        5.4.83-v8 #1
[240459.856810] Hardware name: Raspberry Pi 3 Model B Rev 1.2 (DT)
[240459.856815] Call trace:
[240459.856829]  dump_backtrace+0x0/0x150
[240459.856835]  show_stack+0x24/0x30
[240459.856843]  dump_stack+0xd8/0x160
[240459.856851]  dump_header+0x48/0x200
[240459.856857]  oom_kill_process+0x1c4/0x1d0
[240459.856862]  out_of_memory+0xe0/0x2c0
[240459.856874]  __alloc_pages_slowpath+0xa08/0xbe0
[240459.856880]  __alloc_pages_nodemask+0x2ac/0x330
[240459.856888]  __handle_mm_fault+0x43c/0xb60
[240459.856894]  handle_mm_fault+0x168/0x1d0
[240459.856902]  do_page_fault+0x148/0x4a0
[240459.856907]  do_translation_fault+0xb0/0xcc
[240459.856913]  do_mem_abort+0x50/0xb0
[240459.856918]  el0_da+0x1c/0x20
[240459.856923] Mem-Info:
[240459.856940] active_anon:83322 inactive_anon:84389 isolated_anon:0
[240459.856940]  active_file:344 inactive_file:524 isolated_file:0
[240459.856940]  unevictable:0 dirty:0 writeback:0 unstable:0
[240459.856940]  slab_reclaimable:13977 slab_unreclaimable:19907
[240459.856940]  mapped:585 shmem:12 pagetables:3195 bounce:0
[240459.856940]  free:3702 free_pcp:71 free_cma:7
[240459.856952] Node 0 active_anon:333288kB inactive_anon:337556kB active_file:1376kB inactive_file:2096kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:2340kB dirty:0kB writeback:0kB shmem:48kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[240459.856967] DMA free:14808kB min:3860kB low:4824kB high:5788kB active_anon:333320kB inactive_anon:337556kB active_file:1560kB inactive_file:2064kB unevictable:0kB writepending:0kB present:970752kB managed:934448kB mlocked:0kB kernel_stack:8096kB pagetables:12780kB bounce:0kB free_pcp:284kB local_pcp:0kB free_cma:28kB
[240459.856973] lowmem_reserve[]: 0 0 0 0
[240459.856991] DMA: 689*4kB (UMEHC) 441*8kB (UMEH) 263*16kB (UEH) 109*32kB (EH) 15*64kB (H) 1*128kB (H) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 15068kB
[240459.857047] 1461 total pagecache pages
[240459.857056] 603 pages in swap cache
[240459.857063] Swap cache stats: add 474561, delete 473954, find 409184/703490
[240459.857069] Free swap  = 0kB
[240459.857075] Total swap = 233608kB
[240459.857082] 242688 pages RAM
[240459.857087] 0 pages HighMem/MovableOnly
[240459.857093] 9076 pages reserved
[240459.857099] 16384 pages cma reserved
[240459.857106] Tasks state (memory values in pages):
[240459.857112] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
[240459.857139] [    103]     0   103    56059      140   409600       95          -250 systemd-journal
[240459.857150] [    122]     0   122     3304       26    53248      292         -1000 systemd-udevd
[240459.857171] [    282]  1003   282     4492      185    65536      872             0 systemd-resolve
[240459.857182] [    283]  1004   283    58236        0    81920      168             0 systemd-timesyn
[240459.857193] [    287]  1001   287     1793      244    45056       50          -900 dbus-daemon
[240459.857204] [    291]     0   291   280284      852   176128      179             0 NetworkManager
[240459.857214] [    302]     0   302    58302        9    77824      246             0 rauc
[240459.857226] [    305]     0   305    75203        0    73728      124             0 rngd
[240459.857237] [    309]     0   309     2756       47    49152      132             0 systemd-logind
[240459.857248] [    313]     0   313     2383       71    45056       97             0 wpa_supplicant
[240459.857259] [    355]     0   355      516        9    28672       18             0 hciattach
[240459.857270] [    359]     0   359     1859       48    36864       45             0 bluetoothd
[240459.857280] [    401]     0   401   410183     5803   339968     1087          -500 dockerd
[240459.857291] [    408]     0   408   626522     2632   356352      861          -500 containerd
[240459.857302] [    569]     0   569   268512        0   118784      168          -500 docker-proxy
[240459.857312] [    575]     0   575   325074      363   147456      135          -499 containerd-shim
[240459.857323] [    590]     0   590       48        0    28672        4             0 s6-svscan
[240459.857334] [    681]     0   681       48        0    28672        3             0 s6-supervise
[240459.857345] [    830]     0   830       48        0    28672        4             0 s6-supervise
[240459.857360] [    833]     0   833   178209      451    94208      214             0 observer
[240459.857371] [    860]     0   860   351921     1690   233472      318             0 docker
[240459.857382] [    861]     0   861      917       15    36864       36             0 agetty
[240459.857393] [    898]     0   898   325490      546   155648      191          -499 containerd-shim
[240459.857404] [    914]     0   914       48        0    28672        4             0 s6-svscan
[240459.857415] [    994]     0   994       48        0    28672        4             0 s6-supervise
[240459.857426] [   1176]     0  1176       48        0    28672        4             0 s6-supervise
[240459.857436] [   1177]     0  1177       48        0    28672        3             0 s6-supervise
[240459.857447] [   1179]     0  1179    37409     7475   319488     7328             0 python3
[240459.857457] [   1180]     0  1180     1092      121    32768      397             0 bash
[240459.857525] [   1498]     0  1498   325426      380   151552      160          -499 containerd-shim
[240459.857537] [   1514]     0  1514       48        0    28672        4             0 s6-svscan
[240459.857547] [   1589]     0  1589       48        0    28672        3             0 s6-supervise
[240459.857558] [   1738]     0  1738   325074      374   155648      155          -499 containerd-shim
[240459.857569] [   1760]     0  1760       48        0    28672        5             0 s6-svscan
[240459.857580] [   1805]     0  1805       48        0    28672        4             0 s6-supervise
[240459.857591] [   1809]     0  1809   179872     1975   110592      435             0 coredns
[240459.857609] [   1882]     0  1882       48        0    28672        4             0 s6-supervise
[240459.857621] [   2099]     0  2099   325426      308   155648      150          -499 containerd-shim
[240459.857632] [   2125]     0  2125       48        0    28672        6             0 s6-svscan
[240459.857643] [   2306]     0  2306       44        0    16384        6             0 foreground
[240459.857653] [   2308]     0  2308       48        0    28672        4             0 s6-supervise
[240459.857664] [   2323]     0  2323       43        0    16384        4             0 foreground
[240459.857675] [   2497]     0  2497      410        0    28672        2             0 sleep
[240459.857685] [   2527]     0  2527   325010      370   155648      125          -499 containerd-shim
[240459.857696] [   2542]     0  2542       48        0    28672        3             0 s6-supervise
[240459.857707] [   2543]     0  2543       48        0    28672        3             0 s6-supervise
[240459.857717] [   2546]     0  2546    23667      121    90112      536             0 pulseaudio
[240459.857729] [   2549]     0  2549     1079        2    36864      504             0 bash
[240459.857739] [   2579]     0  2579       48        0    28672        4             0 s6-svscan
[240459.857749] [   2586]     0  2586     1080        0    36864      503             0 bash
[240459.857760] [   2587]     0  2587     1282        1    45056       79             0 udevadm
[240459.857770] [   2623]     0  2623       48        0    28672        3             0 s6-supervise
[240459.857781] [   2800]     0  2800       48        0    28672        3             0 s6-supervise
[240459.857792] [   2804]     0  2804      217       11    28672        0             0 mdns-repeater
[240459.857802] [   2856]     0  2856   323811        0   135168      189          -500 docker-proxy
[240459.857813] [   2865]     0  2865   343859      342   163840      138          -499 containerd-shim
[240459.857824] [   2882]     0  2882       48        3    28672        1             0 s6-svscan
[240459.857835] [   2959]     0  2959       48        0    28672        3             0 s6-supervise
[240459.857845] [   3193]     0  3193   325074      353   151552      154          -499 containerd-shim
[240459.857860] [   3241]     0  3241       48        0    28672        5             0 s6-svscan
[240459.857871] [   3377]     0  3377       48        0    28672        3             0 s6-supervise
[240459.857881] [   3498]     0  3498   325074      297   147456      131          -499 containerd-shim
[240459.857892] [   3541]     0  3541       48        0    28672        4             0 s6-svscan
[240459.857903] [   3685]     0  3685       48        0    28672        4             0 s6-supervise
[240459.857914] [   3882]     0  3882       48        0    28672        3             0 s6-supervise
[240459.857925] [   3883]     0  3883       48        0    28672        3             0 s6-supervise
[240459.857935] [   3885]     0  3885     1061       35    36864       87             0 sshd
[240459.857945] [   3888]     0  3888     5369       13    77824     4173             0 ttyd
[240459.857956] [   3986]     0  3986       48        0    28672        4             0 s6-supervise
[240459.857967] [   3990]     0  3990    75694    10352   811008     2423             0 node
[240459.857980] [   4339]     0  4339       48        0    28672        4             0 s6-supervise
[240459.857991] [   4340]     0  4340       48        0    28672        3             0 s6-supervise
[240459.858001] [   4343]     0  4343     6943       73    90112      334             0 nmbd
[240459.858012] [   4345]     0  4345    10642       68   114688      479             0 smbd
[240459.858023] [   4362]     0  4362    10143       74   106496      445             0 smbd-notifyd
[240459.858034] [   4363]     0  4363    10145       51   106496      468             0 cleanupd
[240459.858045] [   4681]     0  4681   325362      328   155648      172          -499 containerd-shim
[240459.858056] [   4724]     0  4724      198        5    28672        4             0 docker-init
[240459.858067] [   4770]     0  4770       48        0    28672        8             0 s6-svscan
[240459.858078] [   4799]     0  4799       48        0    28672        4             0 s6-supervise
[240459.858089] [   4992]     0  4992   325426      370   151552      127          -499 containerd-shim
[240459.858100] [   5041]     0  5041       48        0    28672        4             0 s6-svscan
[240459.858111] [   5396]     0  5396       48        0    28672        3             0 s6-supervise
[240459.858121] [   5577]     0  5577       48        0    28672        4             0 s6-supervise
[240459.858132] [   5583]     0  5583     7578      137    94208     4540             0 hass-configurat
[240459.858142] [   5835]     0  5835   305378        0   126976      179          -500 docker-proxy
[240459.858153] [   5890]     0  5890   325074      341   155648      134          -499 containerd-shim
[240459.858164] [   5909]     0  5909      198        4    28672        5             0 docker-init
[240459.858174] [   5971]     0  5971    11823     2203   122880     4635             0 python3
[240459.858184] [   6333]     0  6333       48        0    28672        4             0 s6-supervise
[240459.858195] [   6335]     0  6335       48        0    28672        3             0 s6-supervise
[240459.858205] [   6338]     0  6338     1484        2    36864      208             0 nginx
[240459.858216] [   6339]     0  6339    15717       14   102400      694             0 php-fpm7
[240459.858231] [   6735]   100  6735    15717        1    90112      709             0 php-fpm7
[240459.858241] [   6736]   100  6736    15717        4    90112      708             0 php-fpm7
[240459.858252] [   6737]   100  6737    15717        4    90112      708             0 php-fpm7
[240459.858262] [   6738] 65534  6738    15716        4    90112      709             0 php-fpm7
[240459.858272] [   6739] 65534  6739    15716        3    90112      709             0 php-fpm7
[240459.858283] [   6741]     0  6741     1541        0    36864      265             0 nginx
[240459.858294] [  75160]     0 75160     4347        2    65536      125             0 git
[240459.858305] [  79602]     0 79602   325362      404   151552      122          -499 containerd-shim
[240459.858315] [  79618]     0 79618       48        0    28672        5             0 s6-svscan
[240459.858326] [  79663]     0 79663       48        0    28672        3             0 s6-supervise
[240459.858336] [  79828]     0 79828       48        0    28672        4             0 s6-supervise
[240459.858346] [  79831]     0 79831   764545   124934  5595136    22663             0 python3
[240459.858357] [ 122931]     0 122931    10706      252   114688      312             0 smbd
[240459.858368] [ 123341]     0 123341     1069       33    40960       99             0 sshd
[240459.858379] [ 123345]     0 123345      894      314    40960        8             0 bash
[240459.858389] [ 123372]     0 123372      411       13    36864        0             0 tail
[240459.858406] [ 126450]     0 126450      410        1    36864        0             0 sleep
[240459.858416] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=f15fb402a18904130ea7617ba8b7756d7b756863d96c3f6a3d570c6512bcf660,mems_allowed=0,global_oom,task_memcg=/docker/f15fb402a18904130ea7617ba8b7756d7b756863d96c3f6a3d570c6512bcf660,task=python3,pid=79831,uid=0
[240459.858971] Out of memory: Killed process 79831 (python3) total-vm:3058180kB, anon-rss:499784kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:5464kB oom_score_adj:0
[240460.101902] oom_reaper: reaped process 79831 (python3), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
[244186.150321] cp210x ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
