Hi everyone,
I’m hoping you can help me with a current issue in my IoT project. I’m working on understanding more about “man-in-the-middle” techniques, where I try to intercept and decode the data traffic of a device. For this, I’m using a microcontroller flashed with ESPHome and an AZDelivery Logic Analyzer in combination with Saleae Logic2 software. Unfortunately, I seem to be making a mistake somewhere because I can’t read the sent UART signal correctly.
Project Setup:
- Microcontroller: ESP8266 with a NodeMCU V2 board
- Logic Analyzer: AZDelivery USB Logic Analyzer, connected via Saleae Logic2
- ESPHome Configuration: Here’s the relevant excerpt from my YAML code:
substitutions:
friendly_name: MITM Intex SWG
esphome:
friendly_name: ${friendly_name}
comment: Proof of concept
min_version: 2024.6.0
uart:
tx_pin: GPIO15
rx_pin: GPIO13
baud_rate: 9600
debug:
direction: BOTH
after:
delimiter: "\n"
switch:
turn_on_action:
- uart.write:
data: [0x55]
Issue:
I’ve captured the UART data traffic at 9600 baud asynchronously in ASCII format, with these settings:
- Tx channel: Channel 0
- Rx channel: Channel 1
However, I’m not seeing clear 0x55
(or ASCII “U”) characters in the Logic Analyzer output when I trigger the switch. Here are some outputs:
- Without trigger, without level shifter:
V\0\xEF(\x18o\x84m(\xFF\xE9\xA9\x99!xC1\xFF\xE3\xD7\x91\xA9\x99\x11\xE1F
- With trigger, without level shifter:
\xA8o\xFD\x98@)\xE8\xFD\xA3M\xFA\xA5+\x98\xCEKJ\xC2\xAC\xF4
- With level shifter, without trigger:
R\x10\xFF[\xEF\xFF\xCC!(\xFFRs\xD7\x
- With level shifter and trigger:
\x98\xDF\xEF(\x18n\x04m(\xFFR\xB8\x16\x04\xFB\xC2\x10\x85\xFD-\xCE\xA5\x1A\x95\x80\x08i
In the ESPHome web server log, the command is shown as sent (Test U Turning ON
), but the Logic Analyzer output doesn’t match what I’m sending.
Question:
Could I have a wrong setting in the Logic Analyzer software, or am I missing an adjustment in the ESPHome YAML setup? Are there any specific tips for asynchronous UART capture (9600 baud) that I may have overlooked?
I’d appreciate any tips on the correct settings in the Logic Analyzer or advice for debugging the signal.
Thanks in advance!
Joscha
