Hello. I have 2 Home Assistant setup on 2 different Raspberry Pi:
SETUP 1: RPi 3B+, Raspbian Buster, Pi Hole, Home Assistant installed as a virtual environment following these instructions, Home Assistant 0.108.9
SETUP 2: RPi 4, Home Assistant installed using Home Assistant image (HassOS 3.13), Home Assistant 0.109.4.
My USB Stick is Aeotec Z-Stick Gen 5.
Here’s my problem. Setup 1 is meant to be temporary, just to test things out. When I installed the Z-Stick on Setup 1, I was able to use /dev/ttyACM0 and things worked as expected. I was able to start the z-wave network and I now have to option to add z-wave devices.
However, when I try to install the Z-Stick on Setup 2, I needed to use /dev/ttyAMA0. This confused me because I thought was /dev/ttyAMA0 for GPIO hats. I thought USB sticks would be found at /dev/ttyACM0. In any case, the Z-Stick was successfully installed but I am unable to start the z-wave network. The system just says “Starting Z-Wave Network…” but the network does not start.
I know it’s not the Z-Stick because it works on my Setup1.
Would appreciate any help.
