Hi - I hope someone can help me - I expect if you know how to do this it’s simple but I’m stretching the boundaries of my knowledge.
I have successfully created a rest sensor to retireve XML status information from my Plusnet Hub 2 router:
- platform: rest
resource: http://192.168.1.254/nonAuth/wan_conn.xml
method: GET
headers:
Referer: http://192.168.1.254/basic_-_status.htm
name: Wan Linestatus Rate List
scan_interval: 60
value_template: "{{ value_json.status.wan_linestatus_rate_list }}"
json_attributes:
- status
This populates the sensor with the following value:
{’@type’: ‘array’, ‘@value’: “[[‘UP’,‘VDSL2’,‘Profile%2017a’,‘156’,‘118’,‘161’,‘78’,‘192’,‘78’,‘138’,‘70’,‘40000’,‘9999’,‘74652000’,‘17731000’,‘fast’], null]”}
I would like to be able to extract the 12th, 13th, 14th and 15th values in this array e.g. ‘40000’,‘9999’,‘74652000’,‘17731000’ into individual sensor values for sync speed down, sync speed up, max sync down, max sync up
I think I probably need to put this in a section something like this:
rest:
- resource: http://192.168.1.254/nonAuth/wan_conn.xml
method: GET
headers:
- name: "sync_down"
value_template: ????
- name: "sync_up"
- name: "max_sync_down"
I have put question marks for the value_template because that’s what I need help with.
The complete XML that comes back from the rest call is like this:
HTTP/1.0 200 Ok
Cache-Control: no-cache,no-store,must-revalidate, post-check=0,pre-check=0
Connection: close
Content-Language: en
Content-Type: text/xml
Expires: 0
Pragma: no-cache
Server: httpd
Set-Cookie: urn=3ba14b51c20b5837; Path=/; HttpOnly
X-Frame-Options: DENY
<status>
<!-- REAL -->
<wan_conn_status_list type="array" value="[['disconnected%3B0%3Bpass'],
['connecting%3B0%3Bpass'],
null]" />
<wan_conn_volume_list type="array" value="[['0%3B0%3B0'],
['0%3B0%3B0'],
['0%3B0%3B0'],
null]" />
<wan_linestatus_rate_list type="array" value="[['UP','VDSL2','Profile%2017a','157','120','161','78','192','78','138','70','40000','9999','74667000','18018000','fast'],
null]" />
<wlan_channel_list type="array" value="[['1','0','1'],
['1','0','1'],
['1','0','1'],
['1','0','1'],
['1','0','1'],
['36','0','36'],
['36','0','36'],
['36','0','36'],
['36','0','36'],
['36','0','36'],
null]" />
<curlinkstatus type="array" value="[['disconnected%3B0'],
['connected%3B59'],
null]" />
<sysuptime value="3839" />
<status_rate type="array" value="[['0%3B0%3B0%3B0'],
['9999000%3B40000000%3B0%3B0'],
['0%3B0%3B0%3B0'],
null]" />
<wan_active_idx value="" />
<link_status value="connected%3Bvdsl%3B59" />
<ip4_info_list type="array" value="[['0%2E0%2E0%2E0%3B0%2E0%2E0%2E0%3B0%2E0%2E0%2E0%3B0%2E0%2E0%2E0%3B0%2E0%2E0%2E0'],
null]" />
<ip6_lla_list type="array" value="[['%3A%3A%2F0'],
['%3A%3A%2F0'],
['%3A%3A%2F0'],
null]" />
<ip6_gua_list type="array" value="[['%3A%3A%2F0%3B%3A%3A'],
null]" />
<ip6_rdns_list type="array" value="[[null],[null],[null]]" />
<!-- END_REAL -->
<!--for home page, login lock-->
<locktime value="1" />
<!--END for home page, login lock-->
</status>
Very grateful for any help.
