Hello, I am new to HA, and trying to learn to automate few things in my home. I have setup my nest and other wifi products via Google assistant and everything is working fine. I like all the beautiful home dashboards people have built using HA and Lovelace, and want to build my own dashboard.
I am planning to order Starling hardware to bring all the nest products to HA via homekit integration.
Before I spent the money the HW, I wanted to get a hang of HA and the integrations, and I am learning a lot.
To use my feit plugs via HA, I thought I will use the HA to Google assistant integration and use automations. I followed the instructions from this web site, and did the following
- Installed Assistant relay as add-on store. Used the instructions from Apipa169 and also from the awesome youtube video Grayson.
- Did all the setup within google developer console and setup assistant relay.
- Used assistant relay’s sandbox to test the interaction between assistant relay and Google assistant. Everything looks good.
My Google assistant was able to turns on/off my porch lights via assistant relay. - Now I moved to HA to setup automation. In the configurations.yaml, I typed the following
rest_command:
assistant_relay:
url: ‘http://homeassistant.local:3000/assistant’
method: ‘post’
content_type: ‘application/json’
payload: ‘{“user”:“xxxxx”, “command”:"{{ message }}"}’
Restarted HA.
Went to configuration - Automation and created a new automation. Here is the data from automations.yaml file
- id: ‘1628975435700’
alias: Relay Test
description: ‘’
trigger: - platform: time
at: ‘14:15:00’
condition: []
action: - service: rest_command.assistant_relay
message: Turn on porch lights # Please note that I tried both with and without double quotes
mode: single
- When I tried, ‘Run actions’ for this automation, nothing happens, and I see the following error message in the HA log.
Logger: homeassistant.components.rest_command
Source: components/rest_command/init.py:147
Integration: rest_command (documentation, issues)
First occurred: 5:18:29 PM (1 occurrences)
Last logged: 5:18:29 PM
Client error http://homeassistant.local:3000/assistant
I do not see any errors in assistant relay log files. This makes me think that HA is unable to even call the assistant relay.
I am completely lost. Please help.
Thanks in advance.
