Hello. I have 3 Shelly temp and Humidity sensors and 2 are unavailable .
Used the " # " command on mqqt to listening and got this
Message 55 received on shellies/shellyht-706C73/sensor/act_reasons at 1:17 PM:
[“sensor”]
QoS: 0 - Retain: true
Message 54 received on shellies/shellyht-706C73/sensor/error at 1:17 PM:
0
Message 53 received on shellies/shellyht-706C73/sensor/ext_power at 1:17 PM:
false
Message 52 received on shellies/shellyht-706C73/sensor/battery at 1:17 PM:
53
Message 51 received on shellies/shellyht-706C73/sensor/humidity at 1:17 PM:
67.0
Message 50 received on shellies/shellyht-706C73/sensor/temperature at 1:17 PM:
20.50
Message 49 received on shellies/shellyht-706C73/info at 1:17 PM:
{“wifi_sta”:{“connected”:true,“ssid”:“Cremita”,“ip”:“10.10.10.73”,“rssi”:-28},“cloud”:{“enabled”:false,“connected”:false},“mqtt”:{“connected”:true},“time”:“”,“unixtime”:0,“serial”:1,“has_update”:false,“mac”:“C8C9A3706C73”,“cfg_changed_cnt”:0,“actions_stats”:{“skipped”:0},“is_valid”:true,“tmp”:{“value”:20.50,“units”:“C”,“tC”:20.50,“tF”:68.90,“is_valid”:true},“hum”:{“value”:67.0,“is_valid”:true},“bat”:{“value”:53,“voltage”:2.81},“act_reasons”:[“sensor”],“connect_retries”:0,“sensor_error”:0,“update”:{“status”:“unknown”,“has_update”:false,“new_version”:“”,“old_version”:“20230913-112531/v1.14.0-gcb84623”},“ram_total”:52384,“ram_free”:41384,“fs_size”:233681,“fs_free”:155871,“uptime”:1}
Message 48 received on shellies/shellyht-706C73/announce at 1:17 PM:
{“id”:“shellyht-706C73”,“model”:“SHHT-1”,“mac”:“C8C9A3706C73”,“ip”:“10.10.10.73”,“new_fw”:false,“fw_ver”:“20230913-112531/v1.14.0-gcb84623”}
Message 47 received on shellies/shellyht-706C73/online at 1:17 PM:
true
Message 46 received on shellies/shellyht-708326/sensor/act_reasons at 1:17 PM:
[“sensor”]
Message 45 received on shellies/shellyht-708326/sensor/error at 1:17 PM:
0
Message 44 received on shellies/shellyht-708326/sensor/ext_power at 1:17 PM:
false
Message 43 received on shellies/shellyht-708326/sensor/battery at 1:17 PM:
74
Message 42 received on shellies/shellyht-708326/sensor/humidity at 1:17 PM:
45.0
Message 41 received on shellies/shellyht-708326/sensor/temperature at 1:17 PM:
22.75
Message 40 received on shellies/shellyht-708326/info at 1:17 PM:
{“wifi_sta”:{“connected”:true,“ssid”:“Cremita”,“ip”:“10.10.10.72”,“rssi”:-63},“cloud”:{“enabled”:false,“connected”:false},“mqtt”:{“connected”:true},“time”:“”,“unixtime”:0,“serial”:1,“has_update”:false,“mac”:“C8C9A3708326”,“cfg_changed_cnt”:0,“actions_stats”:{“skipped”:0},“is_valid”:true,“tmp”:{“value”:22.75,“units”:“C”,“tC”:22.75,“tF”:72.95,“is_valid”:true},“hum”:{“value”:45.0,“is_valid”:true},“bat”:{“value”:74,“voltage”:2.87},“act_reasons”:[“sensor”],“connect_retries”:0,“sensor_error”:0,“update”:{“status”:“unknown”,“has_update”:false,“new_version”:“”,“old_version”:“20230913-112531/v1.14.0-gcb84623”},“ram_total”:52384,“ram_free”:40808,“fs_size”:233681,“fs_free”:155871,“uptime”:1}
Message 39 received on shellies/shellyht-708326/announce at 1:17 PM:
{“id”:“shellyht-708326”,“model”:“SHHT-1”,“mac”:“C8C9A3708326”,“ip”:“10.10.10.72”,“new_fw”:false,“fw_ver”:“20230913-112531/v1.14.0-gcb84623”}
Message 38 received on shellies/shellyht-708326/online at 1:17 PM:
true
Message 37 received on shellies/announce at 1:17 PM:
{“id”:“shellyht-706FB7”,“model”:“SHHT-1”,“mac”:“C8C9A3706FB7”,“ip”:“10.10.10.71”,“new_fw”:false,“fw_ver”:“20230913-112531/v1.14.0-gcb84623”}
Message 36 received on shellies/shellyht-706FB7/sensor/act_reasons at 1:17 PM:
[“periodic”]
Message 35 received on shellies/shellyht-706FB7/sensor/error at 1:17 PM:
0
Message 34 received on shellies/shellyht-706FB7/sensor/ext_power at 1:17 PM:
false
Message 33 received on shellies/shellyht-706FB7/sensor/battery at 1:17 PM:
100
Message 32 received on shellies/shellyht-706FB7/sensor/humidity at 1:17 PM:
67.0
Message 31 received on shellies/shellyht-706FB7/sensor/temperature at 1:17 PM:
23.38
Message 30 received on shellies/shellyht-706FB7/info at 1:17 PM:
{“wifi_sta”:{“connected”:true,“ssid”:“Cremita”,“ip”:“10.10.10.71”,“rssi”:-57},“cloud”:{“enabled”:false,“connected”:false},“mqtt”:{“connected”:true},“time”:“”,“unixtime”:0,“serial”:1,“has_update”:false,“mac”:“C8C9A3706FB7”,“cfg_changed_cnt”:0,“actions_stats”:{“skipped”:0},“is_valid”:true,“tmp”:{“value”:23.38,“units”:“C”,“tC”:23.38,“tF”:74.07,“is_valid”:true},“hum”:{“value”:67.0,“is_valid”:true},“bat”:{“value”:100,“voltage”:3.01},“act_reasons”:[“periodic”],“connect_retries”:0,“sensor_error”:0,“update”:{“status”:“unknown”,“has_update”:false,“new_version”:“”,“old_version”:“20230913-112531/v1.14.0-gcb84623”},“ram_total”:52384,“ram_free”:39304,“fs_size”:233681,“fs_free”:155871,“uptime”:1}
Message 29 received on shellies/shellyht-706FB7/announce at 1:17 PM:
Message 28 received on shellies/shellyht-706FB7/online at 1:17 PM:
true
Message 27 received on shellies/shellyht-706C73/sensor/act_reasons at 1:11 PM:
[“sensor”]
Message 26 received on shellies/shellyht-706C73/sensor/error at 1:11 PM:
Logger: homeassistant.components.shelly
Source: helpers/update_coordinator.py:347
integration: Shelly (documentation, issues)
First occurred: 1:05:13 PM (2 occurrences)
Last logged: 1:05:13 PM
- Error fetching shellyht-708326 data: Sleeping device did not update within 43200 seconds interval
- Error fetching shellyht-706C73 data: Sleeping device did not update within 43200 seconds interval
How can I fix them?
