since beginning I’m using; http://homeassistant.local:8123 to get access to HA. As my network system, Openmediavault is using a static IP and since then no access issue, I want the same for HA.
My router has a DHCP range from 100 to 199, So for HA I will use (IPv4):
static IP: 192.168.0.250 → above DHCP range
Gateway: 192.168.0.254 → default from my router
DNS: 213.33.99.70, 80.120.17.70 → default from HA
Thany you very much for your detailed answer. Unfortunately it did not work. I have changed according to my post:
DNS:80.120.17.70
pushed the save button and nothing happened. The save animation did not stop. After some minutes I closed HA and did restart. Now I could see at network the new settings, but have to open HA in the old way…http://homeassistant.local:8123/
