Need help Geo Smart Pro Fan
does anyone know how i can add my smart fan to home-assistant the app is geo smart pro fan
geo smart pro ltd
cant find integration please does anyone have this in home assistant.
There seems to be no remote included, so faking a remote with an ESPHome or similar device is out.
There seems to be no API, so a normal integration is out
There seems to be no homepage, so a scrape/rest interface is out.
I can not see how the communication between the app a f fan occur, but if it is through the internet, then it is most likely encrypted and therefore reverse engineering is out.
Your only hope seems to be if it is local communication only, which can be tested by cutting the internet connection and see if you can still control it.
Thanks WallyR for the information looks like ill have to wait and hope someone makes this work in HA
I think you should hope for the vendor to make an integration possible.
The chance of reverse engineering the protocol if it is encrypted is very small.
Maybe ask the vendor directly. It could be to their benefit too.
a workaround
got this to work using alexa service i created scripts to use this commands turn on off set speed 1 2 3
service: media_player.play_media
media_content_id: turn off living room fan
media_content_type: custom
enqueue: play
device_id: echo show
