Need help installing esp32
hay i got an esp32 from azdelivery but i cant connect it to esp home i get this error everytime i try to flash it
*** missing SConscript file '/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build-esp32.py'
File "/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build.py", line 161, in <module>
im still quite new to homeassistant so please dumb it down for me thanks in advanced for helping
Have you prepared an ESPhome YAML source file to compile and load? Did you use https://web.esphome.io/ to load the minimal stub ESPhome code into the ESP32, first? You need to use the Chrome browser to do this.
i did it through chrome now and yes i used the https://web.esphome.io/ i also can go to the dashboard of the esp after you put in your network details but i still get this error while adding it to esphome
INFO ESPHome 2024.3.0
INFO Reading configuration /config/esphome/esphome-web-965f58.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-965f58 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
========================== [FAILED] Took 2.46 seconds ==========================
and this is my yaml
substitutions:
  friendly_name: ESPHome Web 965f58
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: '1.0'
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
Good job posting your YAML input file, properly formatted. :revolving_hearts:
I’m not nearly as familiar with setting up a wifi access point in ESPhome, but I have to wonder about the empty/null braces beside ap:. I would expect to see some of the optional configuration parameters from WiFi Component — ESPHome there.
im planing on conecting al kinds of sensors to controll my aquariums not tying to make a wifi axcess point i had somthing that worked but stoped so i desided to start a new my old yaml looked like
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-965F58"
    password: "xxxxxxxx"
captive_portal:
switch:
  - platform: gpio
    name: "Heater Basalt Cave"
    pin: GPIO14
  - platform: gpio
    name: "Co2 Valve Basalt Cave"
    pin: GPIO27
  - platform: gpio
    name: "Air Valve Basalt Cave"
    pin: GPIO26
  - platform: gpio
    name: "Prime Pump Vasalt Cave"
    pin: GPIO12
# Dallas temperature sensor
dallas:
  - pin: GPIO25  # Set pin 4 for one-wire bus communication
    update_interval: 5s
  - platform: dallas
    address: 0x3700000083167028
    name: "Inlet Temperature Basalt Cave"
  - platform: dallas
    address: 0x4700000083215e28
    name: "Outlet Temperature Basalt Cave"
binary_sensor:
  - platform: gpio
    name: Emptey Basalt Cave
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: true
    filters:
      # Small filter, to debounce the switch
      - delayed_on: 25ms
      - delayed_off: 25ms
  - platform: gpio
    pin:
      number: GPIO33
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 25ms
      - delayed_off: 25ms```
Use the option to “clean build files”
hey there i tried that now to
Install esphome-web-965f58.yaml
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.1.3
INFO Installing esphome/AsyncTCP-esphome @ 2.1.3
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
also i dont get why i get a wanring on pin 12 i have nothing connected to the board at the moment
okay for others with this problem i deleted my full esphome folder in homeassistant and after installing the add on again it seems to be working i dont know why or how but it seems to be fixed for now i hope it dosent happen again because i have 16 aquariums and i dont want to delete all of them to fix one thanks for the help every one
