Hi guys,
First up, I have only been hacking away at HASS on my RPI for less than 24 hours with the primary goal of getting CEC working so its safe to say I’m a RPi noob but have a few months of intensive HASS experience.
I have been using a Docker image of HASS on my NAS or some months now but getting HASS running on a RPi is far more time consuming than I am used to versus a Docker image. If there is a mistake to make, I have probably made it. I am learning everything I need to know about Python and its Virtual Environments ‘on the job’ so it’s probably safer to assume I know very little or enough to be dangerous when explaining things to me.
I have successfully installed the AIO installer for HASS and appear to have successfully compiled and installed LibCEC as per the RPi instructions but I am yet to figure how to symlink it to HASS so it can use it.
Pretty sure all I need to do to get it working is figure out what directory the virtual environment for HASS is in or something, so I can complete this command??
virtualenv --system-site-packages HASS_VIRT_ENV_DIR
Yes, no, maybe?
Would I be correct in thinking that this directory should be the same for everyone using the default settings like I am and thus what worked for someone else should work for me?
Is there anyone who has got HDMI-CEC working that could steer me in the right direction please?
Cheers!
