Need help integrating Njoy Keen 600 with HASS running directly on RPI4
I am running latest HASS core 2024.7.4, Supervisor 2024.08.0, OS 12.4 on a Raspberry Pi4 and I am trying to connect it to a USB-HID manageable Njoy Keen 600 UPS (specified in the NUT compatibility list).
My UPS is shown in lsusb:
Bus 001 Device 005: ID 1a86:7523
I have installed the NUT add-on and configured it like such:
However, when I am starting the add-on, I get the following permissions error message:
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.13.1
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.7.4
Home Assistant Supervisor: 2024.08.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[14:13:13] INFO: Configuring timezone (Europe/Bucharest)…
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/nut.sh
[14:13:15] INFO: Setting mode to netserver…
[14:13:15] INFO: Generating /etc/nut/upsd.users…
[14:13:16] INFO: Configuring user: nut
[14:13:17] INFO: Configuring Device named myups…
[14:13:17] INFO: Starting the UPS drivers…
libusb1: Could not open any HID devices: insufficient permissions on everything
No matching HID UPS found
Network UPS Tools - Generic HID driver 0.47 (2.8.0)
USB communication driver (libusb 1.0) 0.43
Driver failed to start (exit status=1)
Network UPS Tools - UPS driver controller 2.8.0
cont-init: info: /etc/cont-init.d/nut.sh exited 1
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Anyone else encountered this issue?
Have you already solve this? If not try just remove config. It’s working pretty nice without out of box with
njoy.
