Need help LSC Smart filament ledlamp [ACTION] add to Hass.io
I just bought a lsc-smart-connect-slimme-filament-ledlamp-7 and successfully flashed it with Tasmota.
But what next!?:thinking:
How do I add this lamp to my Hass.io and be able to adjust color and brightness❔
In the tasmota console enter the command setoption19 1
Thank you for your reply francispFrancis,
This gives me the possibility to add it to Hass,io :+1:
But not the possibility to adjust color-temp and brightness :cry:
Did you choose the correct template in tasmota ?
Not sure,
I followed this (sorry site is in Dutch) https://hack42.nl/wiki/Home_Automation,_Domotica_en_Internet_of_Things/LSC_Smart_Filament_Led
and added this backlog via the console:
backlog template {"NAME":"ActionFilaLed","GPIO":[0,0,0,0,0,0,0,0,38,0,37,0,0],"FLAG":0,"BASE":18}; PowerRetain 1; SensorRetain 1; SwitchRetain 1; ButtonRetain 1; SensorRetain 1; module 0
The template in my Tasmota is now:
If you click on the light when it is on, you should see a slider.
No, Not by this one, or any other "light card’ for that matter in my home screen.
I found this on the community page: and added it to my MQTT.yaml (changed ‘Filament gang lamp’ to ’ staandelamp’ )but see no change to.
 - platform: mqtt
    name: "Filament gang lamp"
    command_topic: "cmnd/sonoff_filament/power"
    state_topic: "stat/sonoff_filament/POWER"
    payload_on: "ON"
    payload_off: "OFF"
    brightness_state_topic: "stat/sonoff_filament/Dimmer"
    brightness_command_topic: "cmnd/sonoff_filament/Dimmer"
    brightness_scale: 100
    color_temp_command_topic: "cmnd/sonoff_filament/CT"
    color_temp_state_topic: "stat/sonoff_filament/CT"
    retain: true
    qos: 2
Your template seems correct :
https://blakadder.github.io/templates/lsc_smart_connect_filament.html
I found this for esphome :
https://gathering.tweakers.net/forum/list_message/60137810#60137810
Thank you, but as I don’t have experience with the ESPHOME, and only have tasmota’s I’ll like to try getting that to work.
Maybe stupid question, but what version of Tasmota is on the bulb ? I remember my action GU10 did not work immediately after using tuya-convert, just ON/OFF
I’m currently running Home Assistant 0.102.3.
and the bulb = Tasmota 7.1.2
