Need help making a sensor for my lawn mower
So I have a ‘dumb’ automatic lawnmower. I’ve attached a door sensor between the mower and the dock so I can tell if it is docked or not. I want to build a template sensor or similar so I can represent the mowers states.
Door sensor closed = Docked
Door sensor open = Mowing
Door sensor open > 2 hrs = Error
The first part seemed easy using templates. How do I represent that the mower in is error if the door sensor is open more than 2 hrs? It usually only takes an 1.5 hrs to mow my lawn and any longer than that, the mower will have got stuck on something.
      lawn_mower_status:
        value_template: '{% if states.binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off %}
          {% if states.binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off.state == "on" %}
            Mowing
          {% else %}
            Docked
          {% endif %}
          {% else %}
          n/a
          {% endif %}'
        friendly_name: 'Lawn Mower Status'
I think this should do it:
lawn_mower_status:
  entity_id: sensor.time
  value_template: >
    {% if is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off', 'on') and (as_timestamp(now()) - as_timestamp(states.binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off.last_changed)) / 60 > 120 %}
      error
    {% elif is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off.state', 'on' %}
      Mowing
    {% else %}
      Docked
    {% endif %}
Just make sure you have the time_date sensor configured:
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
Here is the complete package I use for exactly same purpose.
Few notes:
  • I use fibaro smart implant input connected to reed switch to detect mover presence in base, so you will find reference to it my package. So my actual sensor iz zwave based.
  • I also use iPhone notifications (actually after 2:15, not after 2h as descriptions would suggest (in Polish :smiley: ), it is controlled by timer that is easy to reconfigure.
  • I have 2 cards in Lovelace configured; one is showing status of mover and one is conditional, that pops up on main dashbord if automover did not returned to base.
  • input_boolean.automover_automation is used to control whole package for winter, if set to false it disables notifications and hides cards from dashboards.
Here is whole code package:
### Automover automation package
# Actual presence detection sensor for automover is:
# sensor.fibaro_system_fgbs222_smart_implant_burglar_5
### Sensors
  sensors:
    automover_status:
      friendly_name: "Automover Status"
      value_template: >-
        {% if is_state('input_boolean.automover_automation', 'off') %}
          Automation Disabled
        {% elif is_state('input_boolean.automover_status', 'off') %}
          Charging
        {% elif is_state('input_boolean.automover_status', 'on') and is_state('input_boolean.automover_out', 'on') %}
          Did not return to the base!!!
        {% else %}
          Working
        {% endif %}
      icon_template: >-
        {% if is_state('input_boolean.automover_status', 'off') %}
          mdi:battery-charging-50
          mdi:close-box-outline
        {% else %}
          mdi:robot-vacuum-variant
        {% endif %}
### Input Boolean
input_boolean:
  automover_out:
    name: Automover did not returned to base!!!
    icon: mdi:robot-vacuum-variant
    initial: off
  automover_status:
  automover_automation:
    name: Enable Automover automation
# Timers
timer:
  automover:
    duration: '02:15:00'
### Automations
automation:
# Automover out of base
  - id: 'automover_left_base'
    alias: Automover Left Base Satation
    initial_state: true
      platform: state
      entity_id: sensor.fibaro_system_fgbs222_smart_implant_burglar_5
      to: '2'
        entity_id: input_boolean.automover_status
      - service: script.rotate_log
          new_log_entry: "Automover is working now"
      - service: timer.start
        entity_id: timer.automover
# Automover returned to base
  - id: 'automover_returned_to_base'
    alias: Automover Returned to Base
    initial_state: true
      platform: state
      to: '0'
      - service: input_boolean.turn_off
        entity_id: input_boolean.automover_out
          new_log_entry: "Automover is charging now"
      - service: timer.cancel
# Notify about automover being out of base for more than 2 hours
  - id: 'automover_out_of_base'
    alias: Automover out of base for more than 2 hours
    initial_state: True
    - platform: event
      event_type: timer.finished
      event_data:
      - service: notify.mobile_app_mireks_iphone
          title: "UWAGA !!!"
          message: "Kosiarka poza bazą ponad 2 godziny!"
Here is status card:
card:
  cards:
    - text: AUTOMOVER
      type: 'custom:text-divider-row'
    - aspect_ratio: 5/1
      entity: sensor.automover_status
      icon: 'mdi:robot-mower-outline'
      layout: icon_name_state
      show_state: true
      styles:
        icon:
          - color: |
                if (entity.state == 'Charging') return 'var(--cyanish)';
                if (entity.state == 'Working') return 'var(--greenish)';
                else return 'var(--alert-text)';
      type: 'custom:button-card'
    - entities:
        - sensor.automover_status
      hours_to_show: 24
      refresh_interval: 5
      type: history-graph
    - entities:
        - entity: timer.automover
      show_header_toggle: false
      type: entities
  type: 'custom:vertical-stack-in-card'
conditions:
  - entity: input_boolean.automover_automation
    state: 'on'
type: conditional
Screenshot 2020-08-23 at 4.04.53
And here is the conditional popup card:
card:
  name: Automover did not return to the base ! ! !
  styles:
    icon:
      - animation: blink 2s ease infinite
      - color: 'rgb(255, 0, 0)'
  tap_action:
    action: none
conditions:
  - entity: sensor.automover_status
    state: Did not return to the base!!!
    state: 'on'
type: conditional
Screenshot 2020-08-23 at 4.06.35
Thanks. I don’t think my sensor has a last change record though.
Wow, that’s certainly more than I asked for. Great work, can’t wait to try this out.
What is script.rotate_log?
Oh, forgot to mention… I created a small custom log script to record events that I wan to know about (just few vs. standard log that records many unwanted items). This script rotate the log entries (20 entries) deleteting the oldest one and adding specific event on top of log. For the mover automation this activity can be safely deleted.
I believe every entity in HA has a last_changed attribute.
try putting this in the template editor and see what you get:
{{ states.binary_sensor.lumi_lumi_sensor_magnet_aq2_ce212304_on_off.last_changed }}
Indeed that worked thanks! Every day’s a school day :slight_smile:
So I did this in a very crude way for my Robomow RM400.
I’m using a Shelly 2.5 providing a 240v socket for the mower docking station.
Having monitored the power consumption(wattage) in various states, I noticed that the average values are different between;
  • Charging Stage 1,2,3,4
  • Idle in Dock
  • Cutting.
So I used the statistics template to create an average reading, and then I have an if statement off that based on the values.
It’s SUPER UGLY, but it seems to be working for me right now.
The really choppy states before the most recent cutting, were me tweaking the if statements.
 - platform: statistics
   name: "Buggy Charging Details"
   entity_id: sensor.buggy_power
   state_characteristic: average_linear
   max_age:
    minutes: 5
   sampling_size: 50
   precision: 1
   lawnmower_state_buggy:
      friendly_name: Buggy - State
      value_template: >
        {% if states.sensor.buggy_charging_details.state| float < 5.5 %}
            Idle
          {% elif states.sensor.buggy_charging_details.state| float < 8%}
            Cutting
          {% elif states.sensor.buggy_charging_details.state | float > 35 %}
            Charging Stage 1
          {% elif states.sensor.buggy_charging_details.state | float > 30 %}
            Charging Stage 2
          {% elif states.sensor.buggy_charging_details.state | float > 22 %}
            Charging Stage 3
          {% elif states.sensor.buggy_charging_details.state | float < 20 %}
            Charging Stage 4
        {% endif %}
I have automated my incredible dumb mower as per @mirekmal post.
Everything works good, with the exception of the initial sensor for registering if the mower is charging or not. I have a Fibaro wall plug, and watt is the only option I have.
The issue is that the mower is programmed to work between 0900-2100. But as you can see from the images, if the mower has started its job before 2100 it might be mowing after. Not quite sure how to set this up.
Programmed to work from 0900 - 2100:
Programmed to work from 0900-2200:
I currently have a binary sensor as this:
  sensors:
    robotklipper_charging:
      value_template: "{{ states('sensor.veggplugg_robotklipper_power')|float > 2 }}"
So if the mower is fully charged, but the time is after 21:00, watt drops to 1.6w, making my binary sensor registering off (for not charging = mowing).
Is there a smarter way I could set this up?
Is there any (slight) difference between power consumtion of just power supply and power supply with automover in base, but not charging?
Otherwise additional condition to be applied based on time of the day (when you could expect moving window or not, but in case of mover not returning to base just after inactivity window start it could be recognized as in base, charging finished… not easy problem.
No difference, except time.
I have tried the past couple days with the following:
- id: '1686679644003'
  description: ''
  - platform: state
    entity_id:
    - binary_sensor.robotklipper_charging
    to: 'off'
    for:
      hours: 0
      minutes: 10
      seconds: 0
  condition:
  - condition: time
    after: 09:00:00
    before: '21:00:00'
    data: {}
    data: {}
      entity_id: timer.automower
  mode: single
- id: '1686679794583'
  alias: Automover returned to base
  description: ''
  - platform: state
    entity_id:
    to: 'on'
    for:
      hours: 0
      minutes: 3
      seconds: 0
  condition: []
    data: {}
      entity_id:
      - input_boolean.automover_out
      - input_boolean.automover_status
    data: {}
  mode: single
- id: '1686679935427'
  alias: Automover being out of base for more than 2 hours
  description: ''
  - platform: event
    event_data:
  condition: []
  - service: notify.mobile_app_daniels_iphone_2
      message: Robotklipper vært ute i meir enn 2t og 15min
    data: {}
  mode: single
So far it has worked pretty good. The marked “out of base” time period was correct, the mower was stuck…under a car :sweat_smile:
