I’m running a P2000 hacs detecting P2000 messages.
creating sensor.p2000. This sensor changes if there is a new P2000 message.
These are a lot of messages.
So I want to create an template sensor only showing new P2000 messages based on search of a string in the original p2000.
Something like:
I quess this is not the right format for such a template.
I wish to see only results in the new sensor.p2000_trigger if it contains one off the strings to search for
Can somebody show me the right direction?
Same question as @jeffreydevos … it seems to be diffucult to find a reliable P2000 input (scraper/RSS feed). @Canedje is your automation still working properly 24/7?
Now and then I do get some info from http://p2000.brandweer-berkel-enschot.nl, but more often then not it only results in ‘Oefening: TEST Code 100 Contact meldkamer Group Talk’. All the RSS pages there seems to be not working.
During the time I used Domoticz with Dashticz I had Alarmeringen.nl feed which still seems to work.
