Need Help! MQTT Non-Blocking
I am working on my home automation project.
The intent is for the switch to work even when NOT connected to MQTT Server and WiFi.
I am using internal code to control the switch and relays.
But the MQTT loop is blocking the code.
Can you help with a code structure, the MQTT and WiFi connectivity should NOT block the switch function.
Appreciate your help.
Thanks,
Abhay
Have you looked at Switch Template?
You’ll be able to make a “fake” switch that switches on and off, even if it doesn’t get the right result.
