Im seeing below errors and not able to update any addon. Also all my google home devices are not discovered.
I smell a network issue. Any pointers please?
All of a sudden everything is broken.
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e59030>; the handler is closed
18-03-25 12:24:51 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
File “uvloop/cbhandles.pyx”, line 201, in uvloop.loop.TimerHandle._run
File “/usr/lib/python3.6/site-packages/aiohttp/web_ws.py”, line 83, in _send_heartbeat
self._writer.ping()
File “/usr/lib/python3.6/site-packages/aiohttp/http_websocket.py”, line 602, in ping
return self._send_frame(message, WSMsgType.PING)
File “/usr/lib/python3.6/site-packages/aiohttp/http_websocket.py”, line 582, in _send_frame
self.transport.write(header + message)
File “uvloop/handles/stream.pyx”, line 636, in uvloop.loop.UVStream.write
File “uvloop/handles/handle.pyx”, line 165, in uvloop.loop.UVHandle._ensure_alive
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e591e8>; the handler is closed
18-03-25 12:24:56 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e593a0>; the handler is closed
18-03-25 12:25:01 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e59558>; the handler is closed
18-03-25 12:25:06 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e59710>; the handler is closed
18-03-25 12:25:11 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e598c8>; the handler is closed
18-03-25 12:25:16 ERROR (MainThread) [asyncio] Exception in callback <bound method WebSocketResponse._send_heartbeat of <WebSocketResponse Switching Protocols GET /homeassistant/api/websocket >>
handle:
self._writer.ping()
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71e59a80>; the handler is closed
18-03-25 12:25:57 INFO (SyncWorker_9) [hassio.docker.interface] Update docker None with homeassistant/armhf-addon-duckdns:1.2
18-03-25 12:25:57 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/armhf-addon-duckdns tag 1.2.
18-03-25 12:25:57 ERROR (SyncWorker_9) [hassio.docker.interface] Can’t install homeassistant/armhf-addon-duckdns:1.2 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 8.8.8.8:53: dial udp 8.8.8.8:53: connect: network is unreachable”).
18-03-25 12:34:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 12:44:23 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 12:54:25 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:04:27 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:14:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:24:30 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:34:32 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:44:34 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 13:54:35 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:04:37 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:14:39 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:24:41 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:34:42 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:44:44 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 14:54:46 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-03-25 15:04:03 INFO (SyncWorker_2) [hassio.docker.interface] Update docker None with homeassistant/armhf-addon-duckdns:1.2
18-03-25 15:04:03 INFO (SyncWorker_2) [hassio.docker.interface] Pull image homeassistant/armhf-addon-duckdns tag 1.2.
18-03-25 15:04:03 ERROR (SyncWorker_2) [hassio.docker.interface] Can’t install homeassistant/armhf-addon-duckdns:1.2 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 8.8.8.8:53: dial udp 8.8.8.8:53: connect: network is unreachable”).
