Filesystem Size Used Available Use% Mounted on
/dev/vg1/volume_1 7.0T 1.5T 5.5T 21% /
tmpfs 64.0M 0 64.0M 0% /dev
tmpfs 4.8G 0 4.8G 0% /sys/fs/cgroup
shm 64.0M 0 64.0M 0% /dev/shm
/dev/md0 2.3G 1.3G 852.8M 61% /data
tmpfs 4.8G 23.5M 4.8G 0% /run/dbus
tmpfs 4.8G 23.5M 4.8G 0% /run/docker.sock
/dev/vg1/volume_1 7.0T 1.5T 5.5T 21% /etc/resolv.conf
/dev/vg1/volume_1 7.0T 1.5T 5.5T 21% /etc/hostname
/dev/vg1/volume_1 7.0T 1.5T 5.5T 21% /etc/hosts
As you can see /data is already having 61% on a brand new fresh install using Docker image homeassistant/amd64-hassio-supervisor:latest . I am wondering what is the proper step to increase the partition size? The reason is that I am getting this error in the log , which keep me from adding addon.
21-12-11 00:10:34 WARNING (MainThread) [supervisor.jobs] “FixupStoreExecuteReload.process_fixup” blocked from execution, not enough free space (0.8GB) left on the device
Appreciate for any help!
