Need help please : button layout
hi,
i created a button but it is seens like this (with thunderbold)
and i want that with round circle on and off
do you know why?
here is my code
configuration.yml
switch:
  • platform: mqtt
    device_class: light
    command_topic: “valve_1”
    payload_on: “30”
    state_topic: “valve_1/state”
    state_on: “on”
    state_off: “off”
    device_class: switch
ui-lovelace.yaml
  • title: main
    icon: mdi:home-outline
    cards:
    • type: entities
      title: Ambience
      show_state: false
      column_width: calc(100%/3)
      entities:
      • entity: switch.vanne1
        icon: mdi:valve
thanks
Please use code tags.
This happened to me with one switch. The thunderbolt icon means that Home Assistant doesn’t know the state of the device. If you click on the thunderbolt, what happens?
I “fixed” my case by flashing the switch with ESPHome. (It was previously running Tasmota).
