Now I have to face the repairs listed in the logs
2022-03-08 05:57:35 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/scenes.yaml contains duplicate key “light.theater_columns_all”. Check lines 35 and 50
2022-03-08 05:57:40 WARNING (MainThread) [homeassistant.components.lovelace] Resources need to be specified in your configuration.yaml. Please see the docs
2022-03-08 05:57:47 ERROR (MainThread) [homeassistant.config] Platform error: sensor - Integration ‘yr’ not found.
2022-03-08 05:57:48 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: State for media_player.denon_6300h should be a string for dictionary value @ data[‘states’][0][‘entities’]. Got None. (See /config/scenes.yaml, line 204). Please check the docs at Scenes - Home Assistant
2022-03-08 05:57:48 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: State for media_player.denon_6300h should be a string for dictionary value @ data[‘states’][0][‘entities’]. Got None. (See /config/scenes.yaml, line 209). Please check the docs at Scenes - Home Assistant
2022-03-08 05:57:48 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: State for media_player.denon_6300h should be a string for dictionary value @ data[‘states’][0][‘entities’]. Got None. (See /config/scenes.yaml, line 214). Please check the docs at Scenes - Home Assistant
2022-03-08 05:57:52 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave for zwave
File “/usr/local/lib/python3.9/site-packages/openzwave/option.py”, line 78, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: “Zwave Generic Exception : Can’t find device /dev/ttyACM0 : [‘NoneType: None\n’]”
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 335, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zwave/init.py”, line 402, in async_setup_entry
options = ZWaveOption(
File “/usr/local/lib/python3.9/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [‘Traceback (most recent call last):\n’, ’ File “/usr/local/lib/python3.9/site-packages/openzwave/option.py”, line 78, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ‘openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t find device /dev/ttyACM0 : [\‘NoneType: None\\\\n\’]”\n’]’
2022-03-08 05:57:52 ERROR (MainThread) [homeassistant.setup] Setup failed for introduction: Integration not found.
2022-03-08 05:57:55 WARNING (MainThread) [homeassistant.components.broadlink.switch] The ‘host’ option near /config/switch.yaml:25 is deprecated, please remove it from your configuration
2022-03-08 05:57:55 WARNING (MainThread) [homeassistant.components.broadlink.switch] The ‘type’ option near /config/switch.yaml:25 is deprecated, please remove it from your configuration
2022-03-08 05:57:55 ERROR (MainThread) [homeassistant.config] Invalid config for [switch.broadlink]: [friendly_name] is an invalid option for [switch.broadlink]. Check: switch.broadlink->friendly_name. (See /config/switch.yaml, line 25). Please check the docs at Broadlink - Home Assistant
2022-03-08 05:57:58 WARNING (MainThread) [homeassistant.components.nest.legacy] The Legacy Works With Nest API is deprecated and support will be removed in Home Assistant Core 2022.5; See instructions for using the Smart Device Management API at Nest - Home Assistant
2022-03-08 05:57:58 ERROR (MainThread) [homeassistant.components.media_player] The denonavr platform for the media_player integration does not support platform setup. Please remove it from your config.
2022-03-08 05:58:01 ERROR (SyncWorker_0) [homeassistant.components.nest.legacy] Connection error while access Nest web service: Authorization Failed
2022-03-08 05:58:04 ERROR (MainThread) [homeassistant.components.kodi.config_flow] Cannot connect to Kodi
File “/usr/local/lib/python3.9/site-packages/jsonrpc_async/jsonrpc.py”, line 33, in send_message
response = await self._request(data=message.serialize())
File “/usr/local/lib/python3.9/site-packages/aiohttp/client.py”, line 634, in _request
break
File “/usr/local/lib/python3.9/site-packages/aiohttp/helpers.py”, line 721, in exit
raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
File “/usr/local/lib/python3.9/site-packages/pykodi/kodi.py”, line 164, in ping
response = await self._server.JSONRPC.Ping()
File “/usr/local/lib/python3.9/site-packages/jsonrpc_async/jsonrpc.py”, line 35, in send_message
raise TransportError(‘Transport Error’, message, exc)
jsonrpc_base.jsonrpc.TransportError: (“Error calling method ‘JSONRPC.Ping’: Transport Error”, TimeoutError())
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 52, in validate_http
await kodi.ping()
File “/usr/local/lib/python3.9/site-packages/pykodi/kodi.py”, line 170, in ping
raise CannotConnectError from error
pykodi.kodi.CannotConnectError
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 229, in async_step_import
await validate_http(self.hass, data)
File “/usr/src/homeassistant/homeassistant/components/kodi/config_flow.py”, line 54, in validate_http
raise CannotConnect from error
homeassistant.components.kodi.config_flow.CannotConnect
2022-03-08 05:58:20 ERROR (MainThread) [homeassistant.components.light] The flux_led platform for the light integration does not support platform setup. Please remove it from your config.
2022-03-08 05:58:24 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py”, line 74, in _async_process_pending_flows
await gather_with_concurrency(
File “/usr/src/homeassistant/homeassistant/util/async_.py”, line 192, in gather_with_concurrency
return await gather(
File “/usr/src/homeassistant/homeassistant/util/async_.py”, line 190, in sem_task
return await task
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 203, in async_init
flow, result = await task
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 230, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data, init_done)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/components/octoprint/config_flow.py”, line 144, in async_step_zeroconf
uuid = discovery_info.properties[“uuid”]
KeyError: ‘uuid’
2022-03-08 05:58:33 WARNING (Thread-8) [matplotlib.font_manager] Matplotlib is building the font cache; this may take a moment.
