Need help reverting Skyconnect USB to Zigbee-only firmware
I am using a Skyconnect USB with multiprotocol enabled. Currently, I am experiencing issues where I cannot control some of my Zigbee devices. I have tried to solve the problem by moving my Home Assistant (Raspberry Pi 4 in Argon One M.2 casing) and updating the Skyconnect USB via Home Assistant SkyConnect, but unfortunately, this did not help.
I’ve tried to revert the Skyconnect to Zigbee-only firmware. I have tried to do this via Flash Silicon Labs radio firmware manually · NabuCasa/silabs-firmware Wiki · GitHub, but I keep getting the message “bash: universal-silabs-flasher: command not found”.
Does anyone have suggestions on how to revert the Skyconnect to Zigbee-only firmware?
I do not think it is possible yet.
It is mentioned as a warning somewhere on the combined matter/ZigBee firmware update description.
I managed to reset the Sky Connect USB to Zigbee-only via the firmware update website. I removed the add-on, but unfortunately, I am unable to add new devices. Currently, only 2 sensors are working via Zigbee.
I wanted to follow up on my previous message regarding the issues I was experiencing with my Sky Connect USB with multiprotocol enabled.
After trying a few things, I was able to “fix” the issue by taking the following steps:
  1. Flashing the Sky Connect USB via the firmware update website
  2. Deleting the add-on
  3. Deleting ZHA
  4. Restoring the latest backup before multiprotocol was enabled
  5. Waiting a couple of hours
As a result, my old Zigbee network was restored and is now back online.
