Need help scraping temperature data from my Weishaupt heat pump (usr-cgi / xml source)
Hi all,
I am new to home assistant and in the process of my first setup.
I have the following problem:
My heatpump with a Dimplex Controller has the option to provide over usr-cgi / xml the data from all sensors.
I am interested in several temperature values.
For starters I tried to scrape only the outdoor temperature.
This adress:
http://192.168.0.27/usr-cgi/xml.cgi?A|1|10
provides the following output:
I am want the value under index 2
I goggled a lot and tried several configs
I also searched here in the community.
So far my config looks like this:
  - platform: scrape
    resource: http://192.168.0.27/usr-cgi/xml.cgi?A|1|10
    select: "/html/body/table/tbody/tr[10]/td[2]/text()"
    unit_of_measurement: °C
    value_template: '{{ value | replace (",", ".") | float }}'
    device_class: temperature
    state_class: measurement
    scan_interval: 60
Sensor is displayed in the dashboard but with value “unknown”
I think the problem is that the temperature value in the HTML source is not between tags but like free text:
So how can I scrape values like that?
You should be able to use a restful sensor, but I need to put the XML through an XML to JSON conversion tool to work out the value template for you.
Can you post the XML from http://192.168.0.27/usr-cgi/xml.cgi?A|1|10 as formatted text please?
(generally posting images of text is a bad idea)
Oh, sorry for that.
Here is the text version.
<PCOWEB>
<PCO>
<ANALOG>
<VARIABLE>
<INDEX>1</INDEX>
<VALUE>13.5</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>2</INDEX>
<VALUE>21.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>3</INDEX>
<VALUE>-999.9</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>4</INDEX>
<VALUE>-8.7</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>5</INDEX>
<VALUE>22.3</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>6</INDEX>
<VALUE>22.5</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>7</INDEX>
<VALUE>22.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>8</INDEX>
<VALUE>43.2</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>9</INDEX>
</VARIABLE>
<VARIABLE>
<INDEX>10</INDEX>
</VARIABLE>
</ANALOG>
</PCO>
</PCOWEB>
Unfortunately you have stripped off all the indentation. It is important to include this.
is this better?
I saved it as .XML, opened it with notepad++ and copy/pasted it here as preformatted text
<PCOWEB>
<PCO>
<ANALOG>
<VARIABLE>
<INDEX>1</INDEX>
	<VALUE>13.4</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>2</INDEX>
	<VALUE>21.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>3</INDEX>
</VARIABLE>
<VARIABLE>
<INDEX>4</INDEX>
	<VALUE>-8.7</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>5</INDEX>
	<VALUE>22.3</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>6</INDEX>
	<VALUE>22.5</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>7</INDEX>
	<VALUE>22.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>8</INDEX>
	<VALUE>43.2</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>9</INDEX>
</VARIABLE>
<VARIABLE>
<INDEX>10</INDEX>
</VARIABLE>
</ANALOG>
</PCO>
</PCOWEB>
Nope. It still does not look like this:
But I can’t copy the indentations, it only selects the text:
Is there an option to save it as “raw”.
I can only save as XML in chrome or edge, than i get what was posted before.
if i use View Source there is even less indentations:
Or i could manually add the identations in notepad++
I tried your suggestion with XML to JSON myself and got the following results:
I found the correct JSONpath:
this is my new config:
  - platform: rest
    json_attributes_path: "$.PCOWEB.PCO.ANALOG.VARIABLE[:1].VALUE"
    json_attributes:
      - VALUE
    value_template: '{{ value_json.VALUE | replace (".", ",") }}'
    name: "Temp Outdoor X"
    method: GET
    scan_interval: 60
senor gets recognized, but it shows value 0°C
if I add “| float” to the value_template, the sensor disappears from dashboard without error message
Any idea why?
Share the text you used. There are a number of things wrong with what you have done.
Here is the JSON text:
  "PCOWEB": {
    "PCO": {
      "ANALOG": {
        "VARIABLE": [
            "INDEX": "1",
            "VALUE": "13.5"
            "INDEX": "2",
            "VALUE": "21.0"
            "INDEX": "3",
            "VALUE": "-999.9"
            "INDEX": "4",
            "VALUE": "-8.7"
            "INDEX": "5",
            "VALUE": "22.3"
            "INDEX": "6",
            "VALUE": "22.5"
            "INDEX": "7",
            "VALUE": "22.0"
            "INDEX": "8",
            "VALUE": "43.2"
            "INDEX": "9",
            "VALUE": "-999.9"
            "INDEX": "10",
            "VALUE": "-999.9"
Sigh. No. The XML.
It is the same as before:
<PCOWEB>
<PCO>
<ANALOG>
<VARIABLE>
<INDEX>1</INDEX>
	<VALUE>13.4</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>2</INDEX>
	<VALUE>21.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>3</INDEX>
</VARIABLE>
<VARIABLE>
<INDEX>4</INDEX>
	<VALUE>-8.7</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>5</INDEX>
	<VALUE>22.3</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>6</INDEX>
	<VALUE>22.5</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>7</INDEX>
	<VALUE>22.0</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>8</INDEX>
	<VALUE>43.2</VALUE>
</VARIABLE>
<VARIABLE>
<INDEX>9</INDEX>
</VARIABLE>
<VARIABLE>
<INDEX>10</INDEX>
</VARIABLE>
</ANALOG>
</PCO>
</PCOWEB>
Put this in your configuration.yaml file and then run a config check, restart if it passes.
rest:
  - resource: http://192.168.0.27/usr-cgi/xml.cgi?A|1|10
    scan_interval: 60
      - name: "Index 2"
        json_attributes_path: "$.response.system"
        value_template: "{{ value_json['PCO']['ANALOG'][1]['VALUE'] }}"
it didn’t show any errors after config check, but it shows only value unknown after restart:
what is the meaning of json_attributes_path: “$.response.system” ?
and could it be a problem that the value in JSON is also in double quotes?
Probably because of the indentation issues with your XML.
Copy and paste mistake. It shouldn’t stop your sensor form working, though you should use:
rest:
    scan_interval: 60
      - name: "Index 2"
No, single line templates must be enclosed in quotes.
Why is indentation so important, I thought whitespace is not relevant for parsing XML?
No, I meant this double quotes:
Could is be a problem, because the REST is returning the value “13.5” and not 13.5?
And because of that it is only displaying 0°C or unknown?
No that is not the issue.
Ok, than maybe a different approach, there is a second option to extract the data.
I can create my own HTML file on the heat pump and specify which values to output.
This is the HTML file on server:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<!--tagparser="/pcotagfilt"-->
<head>
 <meta content="text/html; charset=ISO-8859-15" http-equiv="content-type">
 <meta http-equiv="refresh" content="15" >
</head>
<body>
<h1><%var(0,2,1)%></h1>
</body>
</html>
This is the HTML file when I open it with browser and view source:
<html>
<head>
</head>
<body>
<h1>23.7</h1>
</body>
</html>
This is my config:
  - platform: scrape
    resource: http://192.168.0.27/temp2.html
    select: "body > h1"
    value_template: '{{ value | replace (".", ",") | float }}'
    scan_interval: 60
Now I get this result:
What am I doing wrong?
