[Need Help] Script doesn't work when executed via shell_command
Hi there,
I’m running HA Core 2023.5.4 on Home Assistant OS 10.1 on a virtual machine (OVA), no docker env.
And I’m trying to run a HA script via automation, calling the shell_command service, to copy files from location “A” to location “B” but it doesn’t work.
However, my shell script works pretty well when executed via HA Terminal directly, for example:
bash /config/shell/cppem.sh
This is the script in HA:
alias: cppem
sequence:
  - service: shell_command.shell_command
    data: {}
mode: single
icon: mdi:script-text-play
This is the related automation part that shall trigger above script to execute:
alias: Copy files each night at 0:02 a.m.
description: ""
  - platform: time
    at: "00:02:00"
condition: []
    data: {}
mode: single
In my configuration.yaml I have the following:
logger:
  homeassistant.components.shell_command: debug
shell_command: !include shell_commands.yaml
In shell_commands.yaml I have:
shell_command: '/config/shell/cppem.sh'
When I now manually trigger the HA script or the automation fires at the desired time, nothing actually happens. Even no log will be written.
So I currently have no clue what’s going wrong or where my mistake is.
This is the cppem.sh script that shall be triggered by the automation:
#!/bin/bash
# Set the source directory
SRC_DIR="/home/myuser/aghcrt"
# Set the target directory
TARGET_DIR="/ssl"
# Set the file names of the two files to copy
FILE1="fullchain.pem"
FILE2="privkey.pem"
# Check if the target directory exists, if not, create it
if [ ! -d "$TARGET_DIR" ]; then
    mkdir -p "$TARGET_DIR"
fi
# Variable to keep track of whether any files were copied
copied_files=0
# Loop through the two files and check if they exist in the target directory
for file in "$FILE1" "$FILE2"; do
    if [ -f "$TARGET_DIR/$file" ]; then
        # If the file exists in the target directory, check if it's older than the file in the source directory
        if [ "$SRC_DIR/$file" -nt "$TARGET_DIR/$file" ]; then
            # If the file in the source directory is newer, copy it to the target directory
            cp "$SRC_DIR/$file" "$TARGET_DIR/"
            echo "Copied $file to $TARGET_DIR"
            copied_files=1
        fi
    else
        # If the file doesn't exist in the target directory, copy it from the source directory
        copied_files=1
    fi
done
# Check if any files were copied and set the exit code accordingly
if [ $copied_files -eq 1 ]; then
    exit 0  # Exit with code 0 to indicate success
else
    exit 1  # Exit with code 1 to indicate no files were copied
fi
Again, this script does its job pretty when executed via HA Terminal (as root) and via
I’d be very happy if someone could tell me what I’m doing wrong here.
Many thanks!
