Need help selecting entities in grouped groups, in Python script
for checking which and how many lights are on, I use this python script, with the entity selecting like this:
for entity_id in hass.states.get(group).attributes['entity_id']:
    state = hass.states.get(entity_id)
which is quite the default way, nothing spectaculair here…
full script below.
But, this is done with the group.all_lights_only, that lists all lights individually, so the entity_id’s in that group are in fact the individual lights.
I have changed my lights groups setup though, so that I nest a few groups, of which the main nestings are:
  all_lights_only:
    name: All lights only
    icon: mdi:lightbulb-outline
    entities:
      - group.all_inside_lights
      - group.all_outside_lights
  all_inside_lights:
    name: All inside lights
    entities:
      - group.main_inside_lights
      - group.guest_inside_lights
      - group.living_ceiling_spots
  all_outside_lights:
    name: All outside lights
    icon: mdi:flood-light
    entities:
      - group.outside_flood_lights
      - group.terrace_outdoors_spots
which of course doesn’t work with the current python_script, because it now sees one of these groups as being the entity_id. I now would need to iterate these groups, which consist of several groups, (that contain groups again), containing lights.
What would be the best way to do so in Python?
I’ve started with this, explicitly listing all groups (to make it easier and not have to iterate groups that contain yet more groups)
light_groups = ['group.main_inside_lights','group.guest_inside_lights',
                'group.living_ceiling_spots','group.outside_flood_lights',
                'group.terrace_outdoors_spots']
for group in light_groups:
        light_ids.append(entity_id)
for entity_id in light_ids: #hass.states.get(group).attributes['entity_id']:
this now does seem to work. But it feels inadequate… As worded in
This is not as elegant as the expand() function we now can easily use in Jinja…
Would appreciate your help here,
thanks for having a look!
dt_prevstate = None
utc_offset = hass.states.get('sensor.utc_offset').state
timeDifference = float(utc_offset)
group = 'group.all_lights_only'
fname = 'Lights'
on_format = 'Lights on: {} -- {}'
off_format = 'No lights on since '
filter = 'on'
pic = 'lamp_off|lamp'
icon = 'mdi:lightbulb'
# min_show = 0
count = 0
desc = ''
    if (state.state == filter or debug):
        dt = state.last_changed + datetime.timedelta(hours= timeDifference)
        time = '%02d:%02d' % (dt.hour,dt.minute)
      # If state changed in the past days show the date too
        if dt.date() < datetime.datetime.now().date():
            time = '{} {}'.format('%02d/%02d' % (dt.day,dt.month),time)
      # check if hue lights are 'reachable' is needed because of allow_unreachable: true
        binary_sensor_id = 'binary_sensor.{}_reachable'.format(state.object_id)
        binary_sensor = hass.states.get(binary_sensor_id)
        if binary_sensor is None or binary_sensor.state == 'on':
            count = count + 1
            desc = '{} {} ({}), '.format(desc,state.name,time)
    else:
        if (dt_prevstate is None):
            dt_prevstate = state.last_changed
        else:
            if (not state.last_changed is None):
                if (state.last_changed > dt_prevstate):
# Final format for the group
picturelist = pic.split('|')
if (count == 0):
    desc = off_format
    picture = picturelist[0]
   # If there is none 'On/Home' state in group, show 'since'
    if (desc.find(' since ') > 0):
        dt = dt_prevstate + datetime.timedelta(hours= timeDifference)
        desc = '{} {}'.format(desc,'%02d:%02d' % (dt.hour,dt.minute))
else:
    desc = on_format.format(count, desc[:-2])
    picture = picturelist[1]
# Create sensor and badge
badge_id = 'sensor.{}_badge'.format(fname.replace(' ', '').lower());
sensor_id = 'sensor.{}_summary'.format(fname.replace(' ', '').lower());
picture = '/local/badges/{}.png'.format(picture)
# badge
hass.states.set(badge_id, count, {
  'friendly_name': '',
  fname: desc,
  'unit_of_measurement': fname + ': ' + str(count),
  'entity_picture': picture,
#  'icon': icon,
# sensor
hass.states.set(sensor_id, count, {
  'friendly_name': fname,
  fname: desc,
#  'unit_of_measurement': badge + ': ' + str(count),
#  'icon': icon,
A hacky way of leveraging the expand() functionality from Jinja templates, which may work (I’ve done similar in one of my Python scripts in order to take advantage of Jinja templating) would be:
Create a template sensor:
    sensors:
      light_entity_ids:
        value_template: >-
          {{ expand("group.all_lights_only") | map(attribute="entity_id") | list | join(",") }}
Then in the Python script, simply use
light_ids = hass.states.get("sensor.light_entity_ids").split(",")
If that doesn’t work, due to the string exceeding the maximum state size (255), you could expose it as an attribute instead:
    sensors:
      light_entity_ids:
        value_template: >-
          {{ expand("group.all_lights_only") | map(attribute="entity_id") | list | count }}
        attribute_templates:
          entity_ids: >-
and then use
light_ids = hass.states.get("sensor.light_entity_ids").attributes("entity_ids").split(",")
thanks! a bit hacky indeed, but yet another interesting option.
Still, I can’t imagine, there isn’t a python replacement for
with the expanded group containing (multiple nested) groups.
Add this function to your python script after desc = ''
def flatten(entity_id, result=[], searched=[]):
    if state is not None:
        entity_ids = state.attributes.get("entity_id")
        if entity_ids is not None:
            searched.append(entity_id)
            for entity_id in entity_ids:
                if entity_id not in result and entity_id not in searched:
                    flatten(entity_id, result, searched)
        else:
            result.append(entity_id)
then change the beginning of your for loop from
to
entity_ids = []
flatten(group, entity_ids)
the flatten function mimics expand()
thanks!
had been experimenting with the flatten function, but thought it would be available already, and not required the definition in the script itself.
can report success :wink:
this is so much better.
Report any issues with it. It’s a recursive function and I tried to trap against circular group configurations. You could get max recursion exceptions, hopefully you won’t.
ok I will be on the lookout.
though, the groups I use don’t have any circular reference. As posted above the top group holds a few sub groups which again hold a few groups, until the last group that only holds single entities. None of the entities (lights) are in any other group.
The whole exercise was about that, so I have been careful in the group configurations.
Yeah I wouldn’t worry about it, I tested it with this setup and it works:
all_lights:
  entities:
    - group.foo
    - group.bar
    - light.bed_light
foo:
  entities:
    - light.ceiling_lights
    - group.bar
bar:
  entities:
    - light.kitchen_lights
    - group.foo
found an issue! Or, more of a challenge really
but not in the python, in a js template referencing the now toplevel group.all_inside_lights:
  - type: custom:button-card
    entity: group.all_inside_lights
    template: button_title_counter
    triggers_update: input_boolean.run_lights_summary
    label: >
      var i;
      var entities = entity.attributes.entity_id;
      var count = 0;
      for (i = 0; i < entities.length; i++) {
        var state = states[entities[i]].state;
        if (state == 'on') {count += 1;}
      if (count == entities.length) return 'All ' + entities.length + ' lights on';
      if (count == 0) return 'No lights on';
      return 'Lights on: ' + count + ' of ' + entities.length;
counted the lights on before, but now, as is to be expected shows only the count of the groups (which now are the entities inside the group.all_inside_lights
so, the question is, can we also ‘flatten’ groups in JS…? some googling suggests we can, but I havent found a real JS replacement for what you made in the python_script.
If you’d have a moment and see a challenge, Id appreciate it. Guess it could be very useful for others too, having a counter iterating groups for entities
Otherwise I fear I’d see myself forced to re-introduce the verbose group…
try converting the python flatten function to JS yourself.
given the fact that this: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/flat would be available, shouldn’t I use that, instead of trying to literally convert the python to js?
would have been nice if something along then lines of
      var i;
      var flattened = entity.flat(4);
      var entities = flattened.attributes.entity_id;
      var count = 0;
would have been possible.
new territories, finding/learning available JS functions…
You don’t have nested arrays, you have nested objects with arrays. You’ll have to make this by hand.
ok will study after dinner :wink:
thanks
Yeah your googling the wrong information. You want to google recursive functions. But if you simply went through the python script and tried to replace each piece with the correct call/syntax for JS, you’d get what you want.
finding myself in new territory trying to define a recursive function in JS, and the translation from Python…
first structural attempt would be something like this, where entity_id is the main group, entities the group members, and e an individual light that will be appended (or not):
function flatten(entity, lights_result, lights_searched){
  return entity; # ??< dont yet see what I should do here..
var lights_result = []
var lights_searched = []
if (entity && entities ) return
              searched.append(entity);  # set the first main group to be the entity
  for (e in entities) {(return e not in lights_result && e not in lights_searched) # check if an entity is in either list
                       ? flatten(e, lights_result, lights_searched) : null ;} # if no, append, if yes, do nothing
return result.append(e);
could you please comment on the most basic of errors…
Just go line by line. You almost have the first line correct.
python
js
function flatten(entity_id, result=[], searched=[])
Now what’s the second line
python
js
… You should know this. How do you get a state using the entity_id in JS?
the line would go here:
       # <- line goes here.
are we looking for
making that line
var state = entity.attributes.entity_id
Close, we are trying to just get the state from the state machine using the entity_id
meaning entity.entity_id, like this in Jinja
       var state = entity.entity_id
and in the next step we need to get the attributes list:
set entities =  entity.attributes.entity_id
recursively:
to finally reach the lights:
(replaced only one group per level for illustrational purposes :wink: )
making the full function like this then:
         function flatten(entity, lights_result= [], lights_searched= []){
           var state = entity.entity_id;
           return state;
           if (state != None) {
               if (entities != None) {
                 searched.append(entities);
                     (! lights_result.includes(e) && ! lights_searched.includes(e))
              return result.append(entities);
and then use this in the actual template…
           return state;
#   var entities = entity.attributes.entity_id; #<--- this needs to become the flattened list of lights so:
   var light_ids = []; # <-- new variable to hold the light_ids
   var entitities = flatten(entity, light_ids);  # <-- flatten group 'entity' in list 'light_ids'
   var i;
   var count = 0;
That’s how I deal with it in button-card (the entity being a group). This returns the number of entities which are on in the group and works for nested groups.
        if (!entity) return 0;
        function loop(list, value) {
          list.forEach(entity => { // This entity is different from the button-card entity, I should have named it differently...
            if (states[entity])
              if (entity.split('.')[0] === "group")
                value = loop(states[entity].attributes.entity_id, value);
              else if (["open", "on"].includes(states[entity].state))
                value++;
          return value;
        return loop(entity.attributes.entity_id, 0);
