ah kk what ip is this 172.30.33.0/24 i be using? i thought i had to use my pfsense 192.168.0.1
And watching at your logs, the cert is not being authenticated.
This is my duckdns, yours have to be like mine (but paste your token):
Nope, i also did the same and didnt work. Put it verbatim like in the docs.
ok i think the duckdns part working no files in the ssl folder is there supposed to be?
["token"] "5c7JzHWUtiA6AD_c4ahkZBn53FCwg0OQEoepRxiuLd4"
["validated"] "2024-05-26T20:50:41Z")
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[16:52:57] INFO: Renew certificate for domains: *****.duckdns.org and aliases:
Processing ******.duckdns.org
+ Signing domains...
+ Generating private key...
+ Generating signing request...
+ Requesting new certificate order from CA...
+ Received 1 authorizations URLs from the CA
+ Handling authorization for ****.duckdns.org
+ Found valid authorization for ****.duckdns.org
+ 0 pending challenge(s)
+ Requesting certificate...
+ Checking certificate...
+ Done!
+ Creating fullchain.pem...
+ Done!
[16:54:05] INFO: Renew certificate for domains: ****.duckdns.org and aliases:
Processing ****.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Aug 24 19:53:03 2024 GMT (Longer than 30 days). Skipping renew!
[16:55:22] INFO: Renew certificate for domains: *****.duckdns.org and aliases:
and since i had so much troubles i dont know what the next step is in this is lol to get this in https mode lol
the article i read said use the ip from the logs… this is the logs is my ip 127.0.0.1:3000? it still boots up slow… and the other ip address you said to use well it wouldnt boot into HTTPS mode
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-npm: starting
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-npm successfully started
s6-rc: info: service npm: starting
s6-rc: info: service npm successfully started
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[17:33:39] INFO: Starting the Manager...
[17:33:39] INFO: Starting NGinx...
[5/26/2024] [5:33:39 PM] [Global ] › ℹ info Using Sqlite: /config/database.sqlite
[5/26/2024] [5:33:40 PM] [Migrate ] › ℹ info Current database version: none
2024/05/26 17:33:46 [error] 199#199: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.0.165, server: nginxproxymanager, request: "GET /api/ HTTP/1.1", upstream: "http://127.0.0.1:3000/", host: "homeassistant:81", referrer: "http://homeassistant:81/nginx/certificates"
[5/26/2024] [5:34:05 PM] [Setup ] › ℹ info Added Certbot plugins certbot-dns-duckdns~=0.9
[5/26/2024] [5:34:05 PM] [Setup ] › ℹ info Logrotate Timer initialized
[5/26/2024] [5:34:05 PM] [Setup ] › ℹ info Logrotate completed.
[5/26/2024] [5:34:05 PM] [IP Ranges] › ℹ info Fetching IP Ranges from online services...
[5/26/2024] [5:34:05 PM] [IP Ranges] › ℹ info Fetching https://ip-ranges.amazonaws.com/ip-ranges.json
[5/26/2024] [5:34:13 PM] [IP Ranges] › ℹ info Fetching https://www.cloudflare.com/ips-v4
[5/26/2024] [5:34:13 PM] [IP Ranges] › ℹ info Fetching https://www.cloudflare.com/ips-v6
[5/26/2024] [5:34:13 PM] [SSL ] › ℹ info Let's Encrypt Renewal Timer initialized
[5/26/2024] [5:34:13 PM] [SSL ] › ℹ info Renewing SSL certs close to expiry...
[5/26/2024] [5:34:13 PM] [IP Ranges] › ℹ info IP Ranges Renewal Timer initialized
[5/26/2024] [5:34:13 PM] [Global ] › ℹ info Backend PID 161 listening on port 3000 ...
[5/26/2024] [5:34:14 PM] [Nginx ] › ℹ info Reloading Nginx
[5/26/2024] [5:34:14 PM] [SSL ] › ℹ info Renew Complete
s6-rc: info: service nginx: stopping
[17:38:59] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service npm: stopping
s6-rc: info: service init-nginx successfully stopped
[5/26/2024] [5:38:59 PM] [Global ] › ℹ info PID 161 received SIGTERM
[5/26/2024] [5:38:59 PM] [Global ] › ℹ info Stopping.
[17:38:59] INFO: Service Nginx Proxy Manager exited with code 0 (by signal 0)
s6-rc: info: service npm successfully stopped
s6-rc: info: service init-npm: stopping
s6-rc: info: service init-npm successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service base-addon-banner: starting
Add-on: Nginx Proxy Manager
Manage Nginx proxy hosts with a simple, powerful interface
Add-on version: 1.0.1
You are running the latest version of this add-on.
System: Home Assistant OS 12.3 (amd64 / qemux86-64)
Home Assistant Core: 2024.5.5
Home Assistant Supervisor: 2024.05.1
[17:42:06] INFO: Starting the Manager...
[17:42:06] INFO: Starting NGinx...
[5/26/2024] [5:42:06 PM] [Global ] › ℹ info Using Sqlite: /config/database.sqlite
[5/26/2024] [5:42:07 PM] [Migrate ] › ℹ info Current database version: none
2024/05/26 17:42:11 [error] 198#198: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.0.165, server: nginxproxymanager, request: "GET /api/ HTTP/1.1", upstream: "http://127.0.0.1:3000/", host: "homeassistant:81", referrer: "http://homeassistant:81/nginx/certificates"
