so i trying to setup home assistant to be HTTPS i have googled… watched videos and read texts but things arent working right …
so maybe someone can help
my router is Pfsense
i port forward 192.168.0.12 port 80 and 443
i forced HA to use the WAN as it normally uses NordVPN to stay behind a VPN not exposed to WAN
i use my own dns but i setup duck dns and got a token
i installed Lets Encrypt Ngnix and Duckns and mariadbs
i setup the NGnix and installed the token and couldnt get it to work
when i did the SSL token under its own tab i get this internal error
Error: Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-36" --agree-tos --email "[email protected]" --domains "hass.daddys.duckdns.org" --authenticator dns-duckdns --dns-duckdns-credentials "/etc/letsencrypt/credentials/credentials-36"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Encountered exception during recovery: certbot.errors.PluginError: The clearing of the TXT record for domain "hass.daddys.duckdns.org" was not successful.
Request status code: 200
Request response text: KO
All nameservers failed to answer the query hass.daddys.duckdns.org. IN TXT: Server Do53:127.0.0.11@53 answered SERVFAIL
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
at ChildProcess.exithandler (node:child_process:422:12)
at ChildProcess.emit (node:events:517:28)
at maybeClose (node:internal/child_process:1098:16)
at ChildProcess._handle.onexit (node:internal/child_process:303:5)
Domain Names *
and i set up the dns as
hass.mydnss.duckdns.org
so i not sure what i doing wrong to get this setup first
from the one article they said i needed 80 so i get confused reading different articles wish HA just offered a Toggle Switch HTTP * or HTTPS * and then it fully did itself cut out the headaches
as for the lets encrpt it add on it doesnt ask for the token just the dns address of the home assistant so i did hass.myaddress.duckdns.org
the duckdns addon asked for the token though… and then i had to change port and change a port in the pfsense as it spit out port 80 was already being used
With ngnix you have to remove that and add another option. Thats why i think is better if you try first with only duckdns addon an port 8123 and check if its working.
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:518
integration: Home Assistant Supervisor (documentation, issues)
First occurred: 9:34:20 AM (1 occurrences)
Last logged: 9:34:20 AM
Found incompatible HTTP option 'server_host'. Watchdog feature disabled
2024-05-26 09:28:19.775 ERROR (MainThread) [homeassistant.config] Invalid config for 'http' at configuration.yaml, line 88: not a file for dictionary value 'http->ssl_certificate', got '/ssl/fullchain.pem', please check the docs at https://www.home-assistant.io/integrations/http
Invalid config for 'http' at configuration.yaml, line 89: not a file for dictionary value 'http->ssl_key', got '/ssl/privkey.pem', please check the docs at https://www.home-assistant.io/integrations/http
@mcarty so i got it to ping finallly… and mydoman.duckdns.org from terminal had to play around and force home assistant to go out my VPN and in through the WAN and then i could get it to ping… i did try the lets encrypt and duckdns but no certificate yet… and my external_url: https://daddys.duckdns.org:8123/
is set too
what should i try now… since i got it to ping
2024-05-26 14:20:51.425 ERROR (MainThread) [homeassistant.config] Invalid config for 'http' at configuration.yaml, line 91: not a file for dictionary value 'http->ssl_certificate', got '/ssl/fullchain.pem', please check the docs at https://www.home-assistant.io/integrations/http
Invalid config for 'http' at configuration.yaml, line 92: not a file for dictionary value 'http->ssl_key', got '/ssl/privkey.pem', please check the docs at https://www.home-assistant.io/integrations/http
what i did was the ngix under the SsL offered download package it had the files and i extracted and copied it to the SSL folder when i \\homeassistant to get to samba shares… as the lets encrypt didnt do anything… to create the files…
so i cant get it to work get this HTTPS
always in safe mode
and the lets encrtyp the error log is
Some challenges have failed.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[16:05:11] INFO: Selected http verification
[16:05:12] INFO: Detecting existing certificate type for *****.duckdns.org
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[16:05:12] INFO: No certificate found - using 'ecdsa' key type.
Requesting a certificate for *****.duckdns.org
Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these problems:
Domain: *******.duckdns.org
Type: unauthorized
Detail: **********: Invalid response from http://******.duckdns.org/.well-known/acme-challenge/SyZD8ta8I78YB7lb7giKMUWjS7gFWDxOcYYPc9FgBnc: 500
Hint: The Certificate Authority failed to download the challenge files from the temporary standalone webserver started by Certbot on port 80. Ensure that the listed domains point to this machine and that it can accept inbound connections from the internet.
