system im using a synology nas running docker.
docker installed using shh
As i don’t have addons so cant use " cloudflare addon" Which previous install of Ha super i did and was working. anyways
steps ive done
docker run -d cloudflare/cloudflared:latest tunnel --no-autoupdate run --token xxxxxxxxxx which shows in docker container and heathy on cloudflare.
cloudflare settings https myiptoha:port on public host to domain.
sub domain to myiptonas:5000
turn off tls no luck
still 502 error.
Yes im new to this so this could be a easy fix just wish i can fix it
only log error
Logger: aiohttp.server
Source: /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py:403
First occurred: 00:38:03 (12 occurrences)
Last logged: 00:54:36
Error handling request
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py”, line 332, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message=“Bad status line ‘Invalid method encountered’”
trying to cast via lovelace i get unable to connect websocket api
