Im having issues getting Z2M working.
Ive installed HA in a proxmox VM on a n100 minipc.
Im using the zbdongle-e and i updated the firmware to ncp-uart-hw-v7.4.5.0-zbdonglee-115200
I have it passed through in proxmox.
Ive tried using chatgpt to find the correct settings, but i no matter what i get:
[2024-12-07 05:38:08] error: z2m: Error while starting zigbee-herdsman
here is my current config file:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://core-mosquitto:1883
version: 5
serial:
port: /dev/ttyACM0
baudrate: 115200
adapter: ember
permit_join: true
Here is the rest of the error log:
[2024-12-07 05:38:08] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
