ardevd
1
So I would like to clean up my configuration.yaml a bit and started splitting it up.
However, I’m a bit confused when it comes to plant sensors. I seemingly cannot do the following:
plant: !include plants.yaml
Is it because the plant component is derived from the sensor
integration?
petro
(Petro)
2
What are the contents of plants.yaml? And is it named plants.yaml or plant.yaml?
ardevd
3
It’s named plants.yaml as specified in the config. The contents of the file is as follows:
# Plants
plant:
zamioculcas:
sensors:
moisture: sensor.zamioculcas_moisture
battery: sensor.zamioculcas_battery
temperature: sensor.zamioculcas_temperature
conductivity: sensor.zamioculcas_conductivity
brightness: sensor.zamioculcas_light
min_moisture: 15
max_moisture: 60
min_battery: 20
min_conductivity: 350
min_temperature: 10
max_temperature: 32
When checking the config I get the following error:
Failed config
General Errors:
- Integration not found: plant
petro
(Petro)
4
Ok, so in configuration.yaml:
and in your plants file
zamioculcas:
sensors:
min_moisture: 15
max_moisture: 60
min_battery: 20
min_temperature: 10
max_temperature: 32
ardevd
5
Thanks, that worked well!
