The goal is to have a ‘virtual switch’ that can be turned on and it
- Programs the Amplifiers input to multiple outputs
- Turns on the output of a media server
- Plays the media server
Amplifier is JUKE
Media Player is OwnTone
I have a switch configured in ’ switches.yaml’
switches:
records_powertoggle:
value_template: "{% if is_state('media_player.forked_daapd_output_juke2', 'on') %}on{% else %}off{% endif %}"
turn_on:
service: media_player.turn_on
entity_id: media_player.forked_daapd_output_juke2
# service: automation.trigger
# data:
# entity_id: automation.new_automation_2
turn_off:
service: media_player.turn_off
switches:
records_skip:
turn_on:
service: media_player.media_next_track
entity_id: media_player.forked_daapd_server
turn_off:
They work.
I a set of SET of REST configured for the JUKE, and I can call the service, and they react correctly.
I thought I could set a ‘scene’ that had a set of services in it to configure the Amplifier, but that needs entities or devices. An Automation needs a TRIGGER.
Do I create a new ‘switch’ with the set of REST commands an call it ‘House_Audio_Set’, then create a Scene with the three switches in it;
- records_powertoggle [sets the output of the media player]
- records_play [calls the play of the media player]
- House_Audio_Set [set the input and outputs of the Amp]
Is there a better way?
