I’m trying to automate the following: If the door openes while I am tagged as away, the code will wait for 15 seconds (giving the sensor time to tag me as home or just arrived). If I am still not tagged as home/just arrived, the automation will send me a notification and alert me that the door has been opened while I am gone.
If the door openes as I arrive, and HA changes me from gone to just arrived, it will greet me with one of the selected messages. I thought this would be pretty straight forward, but I am far from an experienced HA user, so does anyone have any input to make this code work as I described above? Thank you so very much in advance for any help or tips you may have!
alias: Door reaction
description: ''
condition:
- condition: state
state: 'on'
entity_id: automation.tag_me_as_away
- wait_template: "{{ is_state('binary_sensor.ytterdor', 'opened') }}"
timeout: 15
- choose:
condition:
- condition: not
conditions:
- condition: state
entity_id: automation.tag_me_as_home
state: 'on'
- condition: state
entity_id: automation.tag_me_as_just_arrived
state: 'on'
sequence:
- service: notify.notify
message: Outer door opened without you being home!
title: Outer door opened!
default:
- data:
message: '{{ (''Velkommen hjem, deres majestet'', ''Hipp hipp, endelig er hans majestet hjemme igjen'', ''Vi har savnet deg, deres majestet'', ''Håper du har hatt en fin dag i dag, deres majestet'', ''Heisann, deres majestet, deilig å se deg igjen'' )|random }}'
entity_id: media_player.stue
service: tts.google_translate_say
language: Norwegian
continue_on_timeout: false
mode: single
This must be a script because automations must have a trigger in it. The difference between automation and script is that the former has a trigger which ensures that it works when the trigger is achieved.
Now to our requirement. We can build an automation. This the basic outline of the automation.
alias: Door Open Notification
description: ''
mode: single
- platform: state
entity_id: binary_sensor.ytterdor
to: 'on'
condition: []
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
- choose:
- conditions:
- condition: or
conditions:
- condition: state
entity_id: device_tracker.your_device
state: home
- condition: state
state: just_arrived
sequence:
- conditions:
- condition: state
state: not_home
sequence:
- service: notify.alexa_media
message: Outer door opened with you being home!
default: []
But this is not complete also I have build it from the limited into that I got form the first post. Accordingly you need to make some modifications. If you need more help, please ask. Always happy to help.
Tried installing node and ended up with error code “bad gateway: 502” when I tried to launch it, which I looked up, and is a different problem entirely. So I think I’ll stick with my current approach in the meantime.
the first time i install node red i have the same problem
i solved by reinstalling node red i make the change on the configuration. clear the web history and after starting i open node red on my phone and it’s work now i’m able to open it everywhere .
don’t know why and how try it
Okay, so below is the code I’ve tried, but it doesn’t seem to work. Nothing happens, regardless of me opnening the door while tagged as present, or whilst being tagged as away. Any ideas?
description: ''
- platform: state
to: opened
condition:
- condition: state
state: 'on'
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
sequence:
- service: tts.cloud_say
message: >-
{{ ('Velkommen hjem, deres majestet', 'Hipp hipp, endelig er
hans majestet hjemme igjen', 'Vi har savnet deg, deres
majestet', 'Håper du har hatt en fin dag i dag, deres majestet',
'Heisann hoppsann, deres majestet, deilig å se deg igjen'
)|random }}
- conditions:
- condition: state
sequence:
message: Outer door opened while you where away!
title: Door opened!
default: []
mode: single
Please copy paste my code as a new automation and change the enity_id if you have to. Then try it and if it works please edit it to your specifications.
That was what I did. What I changed from your code was
adding the condition for me being away to begin with (otherwise the automation will trigger everytime the door opens regardless of me already being present or not),
changing the order of the conditions and sequences, since it looked to me in your code that HA will notify me that someone entered the door when detecting me at home, and that it will greet whoever comes trough the door when I’m not.
Correct, that’s the condition I want to have before the automation is triggered. If that automation is in state ‘on’, that means that I am tagged as away from the house. The trigger, which will initate the automation that will react to the door then opening is:
- platform: state
to: opened
Which checks wether or not the door has been opened.
Oh wow, that definetly helped! The automation triggers now, as my speaker greeted me. But I think I messed up the order, since it should have sent me a notification since I was tagged as away. Did I do the order wrong in my code above?
The entity ids you are using are not right. You are using automations instead of device trackers. If you see my script you can see that I have used device_trackers which is the way to check if you are home or not. Please check. What is the device_tracker entity id of your device?
Also the condition should not be automation as I said before, it should be again a device_tracker entity.
No, this just means, your automation is on, as in activated. It simply does show that this automation is ready to run and not disabled. You do know, that you can deactivate automations, eg. if you are away disable the morning-coffee-machine-automation, so the machine doesn’t get turned on.
This has nothing to do with how or when or why the automation is run…
alias: React
description: "
- platform: state
to: 'on'
condition:
- condition: state
state: not_home
entity_id: device_tracker.galaxy_s8
- condition: state
state: not_home
entity_id: device_tracker.galaxy_buds_e879
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: home
- condition: state
state: home
sequence:
message: >-
)|random }}
- conditions:
- condition: state
state: not_home
- condition: state
state: not_home
sequence:
message: Ytterdøren ble åpnet uten at du var hjemme!
title: Ytterdør åpnet!
default: []
mode: single
I’ll do some testing and see how this turns out! Let me know if you see som obvious errors!
Thanks again for all the help, I really appreciate it!
