Need help to calculate Total Watt from sensor
I had a sensor outputting live power readings via MQTT to HA in Watt.
How can I calculate the total power used / hour / day.
Is there any way that I can store the day’s usage and add it up to calculate the total usage for the month.
Thanks in advance.
if your output looks like a square sign wave, use the integration integration. It gets the area under the watt curve, which is the result you are looking for, a Wh. But you can make it into a kWh so it matches your monthly bill.
  - platform: integration
    source: sensor.current_power
    unit_prefix: k
    round: 2
    method: left
If your live output reading is more of a ‘flowing sign wave’, change the method to trapezoidal. But be warned, trapezoidal can get wildly incorrect numbers if your device sits at 0 watts for hours on end. You do not want to use this for a washing machine or something like that.
Once you have that sensor, you can use the utility meter integration to calculate even more stuff.
Thank you, will try this out and peek you posted.
