My old compiled codes works fine, apart from its not updating HA. But it gets proper values for the template sensor. Now, I am trying to “updated” it, after updating ESPHome version.
It started with just “parse_float” issue that is suppose to be “parse_number” now, but if I just change that, I get a lot more errors =( Why life cannot be simple?
This is my old code:
- mac_address: E9:F5:D3:BB:1C:30
service_uuid: 2A03
then:
- lambda: |-
std::string b(x.begin(), x.end());
std::string myStr = &b[0];
float num_float = parse_float(myStr).value();
ESP_LOGD("PowerMeter_sensor_instant_power:", "%s", &b[0] );
id(PowerMeter_sensor_instant_power).publish_state(num_float);
service_uuid: 2A04
then:
- lambda: |-
ESP_LOGD("PowerMeter_sensor_pulse_hour:", "%s", &b[0] );
id(PowerMeter_sensor_pulse_hour).publish_state(num_float);
service_uuid: 2A05
then:
- lambda: |-
ESP_LOGD("PowerMeter_sensor_pulse_day:", "%s", &b[0] );
id(PowerMeter_sensor_pulse_day).publish_state(num_float);
If I change from parse_float to parse_number, I get these errors:
config/esphome/m5atom-lite.yaml: In lambda function:
/config/esphome/m5atom-lite.yaml:45:43: error: no matching function for call to 'parse_number(std::__cxx11::string&)'
float num_float = parse_number(myStr).value();
In file included from src/esphome/core/application.h:9:0,
from src/esphome/components/api/api_connection.h:4,
from src/esphome.h:2,
from src/main.cpp:3:
src/esphome/core/helpers.h:375:13: note: candidate: template<class T, typename std::enable_if<(std::is_integral<_Tp>::value && std::is_unsigned<_Tp>::value), int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const char*, size_t)
optional<T> parse_number(const char *str, size_t len) {
src/esphome/core/helpers.h:375:13: note: template argument deduction/substitution failed:
/config/esphome/m5atom-lite.yaml:45:43: note: cannot convert 'myStr' (type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}') to type 'const char*'
src/esphome/core/helpers.h:384:13: note: candidate: template<class T, typename std::enable_if<(std::is_integral<_Tp>::value && std::is_unsigned<_Tp>::value), int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const string&)
optional<T> parse_number(const std::string &str) {
src/esphome/core/helpers.h:384:13: note: template argument deduction/substitution failed:
/config/esphome/m5atom-lite.yaml:45:43: note: couldn't deduce template parameter 'T'
src/esphome/core/helpers.h:389:13: note: candidate: template<class T, typename std::enable_if<(std::is_integral<_Tp>::value && std::is_signed<_Tp>::value), int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const char*, size_t)
src/esphome/core/helpers.h:389:13: note: template argument deduction/substitution failed:
src/esphome/core/helpers.h:398:13: note: candidate: template<class T, typename std::enable_if<(std::is_integral<_Tp>::value && std::is_signed<_Tp>::value), int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const string&)
src/esphome/core/helpers.h:398:13: note: template argument deduction/substitution failed:
src/esphome/core/helpers.h:403:13: note: candidate: template<class T, typename std::enable_if<std::is_same<T, float>::value, int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const char*, size_t)
src/esphome/core/helpers.h:403:13: note: template argument deduction/substitution failed:
src/esphome/core/helpers.h:412:13: note: candidate: template<class T, typename std::enable_if<std::is_same<T, float>::value, int>::type <anonymous> > esphome::optional<T> esphome::parse_number(const string&)
src/esphome/core/helpers.h:412:13: note: template argument deduction/substitution failed:
/config/esphome/m5atom-lite.yaml: In lambda function:
/config/esphome/m5atom-lite.yaml:55:43: error: no matching function for call to 'parse_number(std::__cxx11::string&)'
/config/esphome/m5atom-lite.yaml:55:43: note: cannot convert 'myStr' (type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}') to type 'const char*'
/config/esphome/m5atom-lite.yaml:55:43: note: couldn't deduce template parameter 'T'
/config/esphome/m5atom-lite.yaml:65:43: error: no matching function for call to 'parse_number(std::__cxx11::string&)'
/config/esphome/m5atom-lite.yaml:65:43: note: cannot convert 'myStr' (type 'std::__cxx11::string {aka std::__cxx11::basic_string<char>}') to type 'const char*'
/config/esphome/m5atom-lite.yaml:65:43: note: couldn't deduce template parameter 'T'
