What I want to acheive : read a text message on/by an alexa device
When trying to use ‘Developement tools → Service’
with ‘notify.alexa_media’, i get an ‘[547851380720] Error handling message: Unknown error’ ending with :
'File "/config/custom_components/alexa_media/notify.py", line 195, in async_send_message
for target in targets:
TypeError: 'NoneType' object is not iterable'
-with ‘tts.cloud_say’, the error is :
Sorry, text to speech can only be called with the notify.alexa_media service
BTW, this error message is also said through the alexa device.
I’ve tryied to follow instructions found on this forum or/and github-alexa_media … no success.
Surely something i’m missing or misunderstanding.
You’re not providing all the information that the service needs. You’re missing target and most likely all the other needed attributes. Take a look at the docs for that custom integration.
I’ve followed the instrcution on the github link (I forgot to mention, sorry …). Uploading: image.png…
with (in yaml mode )
service: notify.alexa_media
message: test
target: alexa_buro
type: tts
no success, and no error on log.
I’ve also tryied ‘tts.cloud_say’
with
service: tts.cloud_say
entity_id: media_player.alexa_buro
message: test
I get the following error :
Sorry, text to speech can only be called with the notify.alexa_media service. Please see the alexa_media wiki for details.https://github.com/custom-components/alexa_media_player/wiki/Configuration%3A-Notification-Component#use-the-notifyalexa_media-service
the above message is also played through alexa_buro, loud and clear
That doesn’t seem correct. You need the name of it, the entity_id of the media player, or the serial number. That doesn’t look like any of those options.
Also, it target appears to be listed. All the examples shows it as a list.
message: test
# G090XXXXXXXXX <- doesn't work without a preceding dash
- G090XXXXXXXXX <- OK, works. Only with a space between - G090xxx
# - alexa_buro <- doesn't work ... the name was as defined (previous)
# - aburo <- doesn't work ... the name is as defines (after change)
type: tts
About the dash / item list, I thank that a dash was required only for/when multiple elements, and not required for a single one.
My mistake, sorry.
tts.cloud say still not working
not so important
A big thank for pointing out my errors.
Any idea why the name is not working/reconnized ?
Well it would be the friendly name of the media_player entity. I would assume it should work if the friendly name of the media_player is ‘alexa_buro’. Or it would be the entity_id of the media_player, which might be something like media_player.alexa_buro
Would anybody be so kind to show me the yaml code that i need to place in the automation action so that the tts reads the below sentence (it is partly in dutch language and probably alexa will not pronounce it correctly but it will help me understand how to build a “dynamic” message …
service: notify.alexa_media_echo
message: Test
The entity is correct and I get an success indication on the button click.
I see as well that the volume adjustment is reflected in HA UI, when I tell my echo to change it.
I also tested the example which worked for someone else, but this doesn´t work either.
message: test
target: AB72C******
type: tts
Have you looked at the Alexa Media Player docs? They cover the yaml pretty well.
your target needs to be alexa media players entity_id’s, but your second example will do TTS to the target. Also, there’s no reason to block out the entity_id as it’s unique to your system and it poses no security threats.
it needs to be formatted properly, and the notification service will have a specific name. notify.alexa_media_echo is not that name, it’s notify.alexa_media.
message: test
target: media_player.echo
type: tts
