hi i got a couple of these Raspi Musi Proto’s so i can do the voice to text to be able to turn on lights etc… but i cant get it work…or figure out how to set it it up or listen to speech say in HA or Node Red
i did try the install for HA
https://raspiaudio.github.io
i set it for proto Home assistant and set it up but there is no microphone option
i found
https://github.com/esphome/media-players/blob/631a6ae895e422ae70d986fe2769075cf4ac1f83/raspiaudio-muse-proto.yaml
but it complains the pin is being used in multiple locations so it wont complile so i cant even use that version
so i could use some help on what to do to get this board to listen to voice commands least the first step havent made it to step 2 of how to connect it to a light like turn on light or the wake up word i set
update…
i did find a new link for the raspi muse that still wont compile this one…
https://github.com/esphome/firmware/blob/02dbdbea9a732a8b05b8fc1627044c0f54b80581/voice-assistant/raspiaudio-muse-proto.yaml
but now i dont know how to incorporate it to listen once it works
